I Have A House With Aluminum Wiring Should I Pigtail Every Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 02:17 PM   #1
I have a house with aluminum wiring should I pigtail every outlet
The lack of grounds may also be causing excessive wattage use. The usage this last month was almost 2500 watts. One of the breakers has been welded into the breaker box. I suspect the breaker is too crowded and over amped. Could either of these problems cause a high wattage use in my house. I live in Dallas we have had a pretty mild winter so far and I recently added 4 '" of insullation.
guyblue is offline   Reply With Quote
Old 01-28-2009, 02:25 PM   #2
Licensed electrician
Rewards Points: 1,770
With AL wiring i would suspect that there is a grounding wire in your cables. It was part of wiring methods before AL wiring started to be used.
If it is not connected to your devices it will not affect how much electric is used. It is there to provide a path back to the panel to trip a breaker.
I would suggest you get your panel looked at if a breaker has become welded to the buss. Breakers should match the wire sizes to properly protect against the wires becoming overheated and causing a fire.
Old 01-28-2009, 02:34 PM   #3
DIYer
Pigtailing using the proper wire nuts is better than nothing, but it's not recommended by the CPSC among others because there is still a hazard.
The breaker welding in is probably unrelated to the Al wiring. Is your panel Federal Pacific Stab-lok by any chance?
Gigs is offline   Reply With Quote
Old 01-28-2009, 02:42 PM   #4
So what you are saying
If the ground is not connected the breaker will never reset and will therefore could cause a fire
Old 01-28-2009, 02:44 PM   #5
DIYer
This is not true at all. Without a ground the breaker works just fine.
Old 01-28-2009, 02:45 PM   #6
reply to ggs
It is a General Electric that is all I can see on breaer box
Old 01-28-2009, 02:49 PM   #7
DIYer
I think you should have a professional look at it. The bus bars are probably damaged if you have a breaker welded in, and there could be damage to the wires in the walls on that circuit too.
Old 01-28-2009, 03:09 PM   #8
Rewards Points: 39
can't a short somewhere, with a piece of equipment or in the wiring, cause the meter to keep cranking around from the circuit the short is located on? It sounds to me like the breaker should have tripped and didn't and there is a lot of power coming through that circuit that shouldn't be. I'm good at expressing things in laymans terms because I'm a layman that's for sure!
Typ0 is offline   Reply With Quote
Old 01-28-2009, 03:13 PM   #9
where is the best place to find s professional
Do you have an idea about how much that might cost
Old 01-28-2009, 03:15 PM   #10
DIYer
To get someone just to come out and assess the damage should not cost more than $100. They might do it free as part of a free estimate.
Old 01-28-2009, 03:25 PM   #11
I had a problem with my air conditioner
The person who replaced my outdoor unit was a master techician he was going to replace the breaker but could not. Could this cause the excessive wattage use?
Old 01-28-2009, 03:33 PM   #12
I just remembered
He also stated there was too many high voltage breakers in use
60 60
60 60
30 30
30 60
30 60
30 15
30 15
15 20
---20
15 20
---20
15 20
---20
15 20
---20
Is this dangerous?
Old 01-28-2009, 04:16 PM   #13
FP Stab LOK AL
Gigs,
Not to steal the post. I have Federal Pioneer Stablok and AL approx 32 years old. Is there an issue with this combo. "Is your panel Federal Pacific Stab-lok by any chance?"
I have changed all connectors to AL rtaed and used paste.
Chemist1961 is offline   Reply With Quote
Old 01-28-2009, 04:45 PM   #14
I second that. Find an old guy who has experience with AL wiring.
220/221 is offline   Reply With Quote
Old 01-28-2009, 05:24 PM   #15
I think this is the best way to go, aluminum wiring isn't something to learn electrical wiring on.
rgsgww is offline   Reply With Quote
Old Wiring, New Outlet atkearns Electrical 9 11-23-2008 12:33 PM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 06:25 PM
60 year old house wiring bigp58 Electrical 1 04-21-2008 11:32 AM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 08:38 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
