I Don't Know How To Use This Connector. Please Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 12:50 AM   #1
Rewards Points: 452
I don't know how to use this connector. please help
I was looking for Raco "The insider" nm connector which you can install from inside the box.
But Home Depot doesn't have this. Instead, HD has a different Halex product for the same sku.
So I bought this one, and don't know how to use it properly to secure the nm cable. There are no instructions on the bag or online.
In the front, there is a slot which I tried to pass wire sheath through from the inlet at top. But it's too tight and will not go through.
Then there's a big hole at the bottom, and an open square in the back.
And what is the tab for? you break it off?
Right now, my wiring is not secure because I can't get the clamp to function properly
pman6 is offline   Reply With Quote
Old 06-07-2013, 05:52 AM   #2
MarginallyQualified
Rewards Points: 2,464
If HD doesn't have them go to a REAL supplier.
Old 06-07-2013, 06:25 AM   #3
Rewards Points: 13,752
The wire passes straight through the fitting, not through the square hole.
Once pulled through that tab acts as a wedge so the wire can not be pulled out through the bottom of the box.
Old 06-07-2013, 06:42 AM   #4
langless28's Avatar
Rewards Points: 152
are you sure hd does not have the black cord grip? i bough a bag of those from my local hd. the grey guys are kind of a PITA. the nm cables go through the circle, then the wedge goes into the thin rectangle. then you need a large opening pair of pliers and squeeze the wedge so it goes into the fitting and cinches down on the romex.
langless28 is offline   Reply With Quote
The Following User Says Thank You to langless28 For This Useful Post:
pman6 (06-07-2013)
Old 06-07-2013, 09:20 AM   #5
Rewards Points: 512
What is the SKU on this? I found Raco's "The Insider" once at HD, and have never found one again. Tis' weird.
Installation is the Reverse of Removal.
Old 06-07-2013, 09:42 AM   #6
JW
mm11's Avatar
Rewards Points: 614
I always use these Arlington connnectors-
They can be installed from the inside of a box also.
mm11 is offline   Reply With Quote
Old 06-07-2013, 10:39 AM   #7
Rewards Points: 512
I find I have a heck of a time getting the cable through the back side of them though.
I use the Insider for cable that has been run without a connector.
Old 06-07-2013, 10:41 AM   #8
Rewards Points: 512
HOME DEPOT
HD does sell a pack of 100
Old 06-07-2013, 10:43 AM   #9
Rewards Points: 452
yes. I am sure.
http://www.homedepot.com/webapp/cata...gry=Search+All
check it out. both with the same sku, same inventory.
I go to check in person, and all they have is grey.
But thanks for the instructions. as long as it works, I don't care which I get.
Old 06-07-2013, 11:29 AM   #10
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Grey is the wet location ones ......lol
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 06-07-2013, 07:33 PM   #11
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
One or two two wire cables pass through the circle on the square end of the connector. Then the tab is inserted into the slot and compressed using arc groove pliers or smack it with a hammer like I do.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
