I Can Feel Buzzing Or "charged" Air Around A Light Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2009, 11:07 PM   #1
I can feel buzzing or "charged" air around a light fixture?
I just replaced an outdoor light fixture - the porch light on our house. The wiring inside was relatively new and clean (compared to a lot of older wiring in our house that I have dealt with), so I'm pretty sure my wiring job in there was done neatly.
Here's the weird part (or maybe it's not weird, you tell me). I turned the light on, and when I put my hand near it I could feel vibrations in the air, like it was "charged" - like the feeling you get when the hair on your arm stands up from static electricity. The entire casing of this light fixture is metal.
So I got out my multimeter just out of curiosity. When I touch both leads to the metal casing of the fixture (one on each side) I am seeing around 2 volts AC on the meter (when the light is on).
Is any of this out of the ordinary? Should I be concerned?
jabrockson is offline   Reply With Quote
Old 03-25-2009, 11:11 PM   #2
It should have read zero volts across a metal fixture. From the fixture to a good ground should probably read less than a volt.
Do others sense this also?
Old 03-25-2009, 11:25 PM   #3
Union Electrician
goose134's Avatar
The meter should be reading potential. You should not have any potential on one side of the fixture to the other. As has been suggested, try the fixture to ground. I knew one guy who got whacked pretty good changing light bulbs in his outdoor sconces because the fixture was hot.
goose134 is offline   Reply With Quote
Old 03-25-2009, 11:37 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what kind of lamp is this? fluorescent maybe? If so, the feeling you feel is not abnormal.
Old 03-26-2009, 09:40 AM   #5
Yes, it takes one of those plug-in type fluorescent bulbs.
I'll get a reading going to ground after work tonight. Thanks for the tips.
Old 03-26-2009, 02:13 PM   #6
Can you 'splain?
Old 03-26-2009, 04:42 PM   #7
nap
You talking to me?
nap's Avatar
Originally Posted by Yoyizit View Post
Can you 'splain?
I don't know the physics of the situation but you can actually get a shock from a fluorescent lamp. I would think it is akin to static electricity which, if you remember rubbing a balloon on your hair or other fun kid stuff, you do "feel" the charge.
Old 03-26-2009, 04:56 PM   #8
This seems sort of related, unless it's faked.
Old 03-26-2009, 07:35 PM   #9
Rewards Points: 1,418
There could be phantom (induced) voltages in the metal frame of the fixture or, heaven forbid, due to a defect the metal frame could be hot. It would be better if it were grounded (a defect would reveal itself instantly by a breaker trip).
Old 03-26-2009, 08:51 PM   #10
Idiot Emeritus
Rewards Points: 1,492
That Youtube video is as real as it gets. You can indeed cause a fluorescent tube to flash by static electricity.
If you're working near a microwave tower, you can grab one end of a fluorescent tube and stick the other end near the dish, and it'll light continuously. You won't feel a shock because at high frequencies electrons tend to travel on the surface of a conductor. In this case, your skin is the conductor, and the electricity travel only on the very outside of it.
Nikola Tesla understood this concept very well, hence he was able to become 'the electric man' without any harm. Sparks off the fingertips, etc.
If the frequency is high enough, the human body can conduct substantial amounts of current without harm.
Rob
micromind is offline   Reply With Quote
Old 03-26-2009, 09:20 PM   #11
Florescent lights can build a pretty significant static surface charge. Making sure the fixture is well grounded may help some.
hayewe farm is offline   Reply With Quote
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 01:49 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
