I Apologize For The Most Noob Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 03:19 PM   #1
Rewards Points: 154
I apologize for the most noob question
But if I want to change the light bulb socket, I would need to turn off the breaker which controls that location, correct? Is that enough or would I need to turn off all electricity coming into the house from outside?
I am ashamed but I am a first time home owner and am trying things on my own.
llckll is offline   Reply With Quote
Old 01-07-2010, 03:24 PM   #2
Turning off the breaker that powers the light socket in question would be sufficient. Still, I like to check for voltage with a meter. If you think that you will be doing some minor electrical work in the future, invest $20 in one and keep safe and sure. I think you will be glad you did.
oberkc is offline   Reply With Quote
Old 01-07-2010, 03:27 PM   #3
Rewards Points: 154
Thanks for that great tip. Can you link me to one that you recommend?
Old 01-07-2010, 03:49 PM   #4
llckll, The Dumbest Question is the one that is not asked.
Good Advice given..........
"Turning off the breaker that powers the light socket in question would be sufficient. Still, I like to check for voltage with a meter. If you think that you will be doing some minor electrical work in the future, invest $20 in one and keep safe and sure"
Here is a link for a tester
http://www.homedepot.com/webapp/wcs/...7X-_-100661787
mark942 is offline   Reply With Quote
Old 01-07-2010, 03:57 PM   #5
Rewards Points: 154
That is true Mark. thanks.
I have a confession. I was trying to unscrew the light bulb socket without the breaker turned off. When I touched the live line, my screwdrivers tip exploded and melted off.
Thank God I was not injured but I definitely learned my lesson. That's why i'm on this forum.
Old 01-07-2010, 03:59 PM   #6
Rewards Points: 154
So would I just stick the tester inside the lightbulb socket to check for electricity after breaker is turned off? What connections would I have to touch?
Old 01-07-2010, 04:01 PM   #7
Rewards Points: 154
Basically, I need to replace the entire socket cause it broke off:
Source - ehow.com
So what part or parts would I touch with the tester?
Old 01-07-2010, 04:58 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
The tab in the bottom and the threads on the side.
Careful, cause you still short out the meter lead.
Are you replaceing a single open light fixture?
It is much cheaper to replace the entire fixture than the socket.
jbfan is online now   Reply With Quote
Old 01-07-2010, 05:02 PM   #9
Rewards Points: 154
Meter lead? I may replace the whole thing then. Sounds easier to replace the entire thing rather than the opening.
Old 01-07-2010, 05:08 PM   #10
jbfan's Avatar
Rewards Points: 478
Sorry, I just looked at the tester and saw the confusion about a meter lead.
Sometime replace is better than repair!
Old 01-07-2010, 05:24 PM   #11
Rewards Points: 154
Is it difficult to replace the whole thing?
Old 01-07-2010, 05:33 PM   #12
jbfan's Avatar
Rewards Points: 478
What kind do you have?
Old 01-07-2010, 06:28 PM   #13
Just call me Andrew
Rewards Points: 1,020
There is no need to apologize for asking any question here, no matter how elementary. It's better to ask a simple question than to hurt yourself or leave a potential safety hazard. Besides, that's why forums like this exist.
Can you post a picture of your current light fixture? Replacing a fixture is pretty easy. Normally, only two wires to connect, black and white.
Andrew
secutanudu is offline   Reply With Quote
Old 01-07-2010, 06:38 PM   #14
Rewards Points: 154
Please excuse the bad quality:
Let me know if you need clearer pictures. I'll take it from my digitial camera.
Old 01-07-2010, 06:39 PM   #15
Rewards Points: 154
Also, when I turn the breaker off, should I wait 5-10 minutes before starting work? Just in case there is leftover "juice" in the electrical line.
re: paint noob question gramps416 Painting 8 12-07-2009 02:45 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
noob wireing question shame302 Electrical 6 05-16-2008 08:33 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
