I Am Renovating Old Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 07:03 PM   #1
I am renovating old bathroom
I am renovating old bathroom It came time to change the switch. It has a light switch, that the fan comes on when the light is turn on. Beside that is a normal set of plugs that is covered by one plate for the light swith and plug. Further is a gfi plug. Wanting to wire the fan on its own and light switch. I am putting the fan switch where the regular plug was wired. I have four black wires not sure how to run them. All of the white are tied together not sure what to do.
homereno is offline   Reply With Quote
Old 01-21-2012, 07:14 PM   #2
MarginallyQualified
Rewards Points: 2,464
...not sure what to do.
Can you get into the attic space above?
If so... it'll be relatively easy.
Old 01-21-2012, 07:14 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Thats a loaded gun ,need more info or atleast a picture
plummen is offline   Reply With Quote
Old 01-21-2012, 07:19 PM   #4
Licensed electrician
Rewards Points: 1,054
Unless there is wiring from the receptacle to the fixture or fan you will need to do some rewiring.
plummen (01-21-2012)
gutting bathroom debiasio Remodeling 30 02-17-2011 03:32 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 08:13 PM
Bathroom Venting on Septic System edro Plumbing 2 01-03-2011 08:41 AM
Re-wiring an existing bathroom Worker-B Electrical 7 08-29-2009 06:16 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
