Old 06-05-2014, 03:15 PM   #1
Share |
Hypothetical Melting question
If you have a 60 amp 2 pole breaker feeder a #4 Al SEU conductor going back to a disconnect on the furnace and the load b wasn't even tightened at all could that cause the main 60 to melt so bad that the plastic behind in drips down the buss bar without even having a sign of arcing in the disconnect ??
Cletis is offline   Reply With Quote
Old 06-05-2014, 03:57 PM   #2
Was there a lightning strike?
For breaker housing to melt there needs a high heat source.
ED
de-nagorg is online now   Reply With Quote
Old 06-05-2014, 05:28 PM   #3
Cletis, just sell the customer a panel change and call it done. Whats going on in the disco has nothing to do with a 60amp breaker melting down, both you and I know that.
Jump-start is offline   Reply With Quote
Old 06-05-2014, 11:39 PM   #4
Yes. Loose connections get hot, higher current loose connections get hotter. i^2R law. Heat of poor joint goes up with the square of the current. Replace damaged parts and check torque on all screws.
curiousB is online now   Reply With Quote
Old 06-06-2014, 05:41 AM   #5
Loose connection at device drawing 2 amps 50 ft away from breaker melting ? So, loose connection is not where the melting is happening. This is all hypothetical of course
Old 06-06-2014, 07:12 AM   #6
Electrical Contractor
kbsparky's Avatar
More than one loose connection at work here.
Or a bad breaker.
Or a combination of things.
-KB
Old 06-06-2014, 10:01 PM   #7
Semi-Pro Electro-Geek
Only the loose connection will get hot, not some other part of the circuit. So check the area that melted and forget the rest.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 06-07-2014, 04:16 AM   #8
[QUOTE=de-nagorg;1359735]Was there a lightning strike?
That was a Cletis strike.
bobelectric is offline   Reply With Quote
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
Hypothetical prefab question. Tommy L General DIY Discussions 3 08-09-2009 10:09 PM
Hypothetical Lightning/Grounding question daxinarian Electrical 21 09-08-2008 10:00 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
