Hydrant And Outside Wall Outlet Distance - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 07:05 AM   #1
hydrant and outside wall outlet distance
I have a cabin in Gatlinburg TN and plan to add a hose bibb near the hot tub. I have a outside electrical outlet around where I would like to add the faucet. Is there a code or recommended distance between water and power on an outside wall? The power to the outlet comes from one on the inside wall and the water will be coming from under the house....if that matters and also the outlet does have one of the waterproof covers
Thanks in advance for any input
Greg
gcan is offline   Reply With Quote
Old 08-24-2012, 07:29 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
No requirement for minimum distance.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-24-2012, 08:39 AM   #3
joed's Avatar
Rewards Points: 11,576
Nothing in the code but I wouldn't put the receptacle below the hose bib.
The Following 2 Users Say Thank You to joed For This Useful Post:
electures (08-24-2012), Speedy Petey (08-24-2012)
Old 08-24-2012, 07:31 PM   #4
the hose bibb will be about 2 feet below and 1+ feet to the right of the receptacle.
thank you for the responses
Old 08-24-2012, 07:32 PM   #5
Licensed electrician
Rewards Points: 1,020
You do need to keep the receptacle at least 5' from the tub.
