HVAC Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 05:42 PM   #1
HVAC Electrical
I had an HVAC company come out and repair my compressor unit. Locked up fan motor. While they were trouble shooting it was found to have a bad breaker outside the house. They cut the wires to the breaker and wire capped them together. First question, will this cause my house to catch fire? Second question, since I am done with these people can I replace these parts at the local home improvement store or is this going to cost me more than I had bargained for?
DIY Dummie is offline   Reply With Quote
Old 05-26-2012, 05:52 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by DIY Dummie View Post
While they were trouble shooting it (the disconnect) was found to have a bad breaker...
Would you rather not have the AC working this weekend?
First question, will this cause my house to catch fire? NO
Second question, since I am done with these people can I replace these parts at the local home improvement store...
You need a new outside disconnect.
In most areas you do NOT need a breaker out there too.
The AC company SHOULD have installed one.
You may be able to put it in yourself.
Look for something like this (about $15):
The Following User Says Thank You to TarheelTerp For This Useful Post:
DIY Dummie (05-26-2012)
Old 05-26-2012, 06:00 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why does he need that when he already had a disconnect installed... Just install a new breaker, they didn't have one, but did what they could... its just being used as a service disconnect.... not sure what the issue was, but order a new fan part and be done with it. And why on earth would the AC company install an electrical disconnect?
Old 05-26-2012, 06:12 PM   #4
Licensed electrician
Rewards Points: 1,630
If they wired the two hots together they created a dead short.
Old 05-26-2012, 06:14 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
Don't need an electrical disconnect if the electrical service panel is on the same exterior wall as the condensing unit. That's how it is down here at least. The breaker itself is the disconnect.
Either way, just purchase a new breaker and have it installed. If you mean the wires are still hanging out of the breaker, cut, and are bare than you'll certainly have issues. If they are capped off then not so much but it's best practice to remove the stub wire altogether or the bad breaker itself.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-26-2012, 06:17 PM   #6
E2 Electrician
my guess is that they tied line to load...
Old 05-26-2012, 10:49 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
A disconnect is required by the NEC (440.14) to be within sight of and accessible from the outside condenser. This requirement is for the safety of servicing technicians. In most cases it is not required that the disconnect be fused. A circuit breaker in the panel will not be acceptable unless the panel is a meter main or exterior mounted panel within sight of the a/c unit. In my career I never came across a residential A/C that did not have a disconnect moounted close by the condenser unit.
Old 05-26-2012, 10:53 PM   #8
Here ya go, from two days ago.
Thanks.
Old 05-26-2012, 11:09 PM   #9
E2 Electrician
Thats awesome, who picked that location for the ac unit?
Old 05-26-2012, 11:26 PM   #10
Probably the original hvac guys when the home was built some 50-60 years ago, judging by the original sunken concrete pad. It must have passed inspection..
Thanks.
Old 05-27-2012, 05:45 PM   #11
Rewards Points: 240
What's with that open meter socket?
fa_f3_20 is offline   Reply With Quote
Old 05-27-2012, 08:58 PM   #12
Missouri Bound's Avatar
So.....you don't need a disconnect in this situation, just the proper sized breaker. But you have a few other issues that need to be corrected immediately.....like closing up the unused meter socket and getting a waterproof cover for that breaker panel.
Do you want it your way or the right way?
Old 05-27-2012, 09:22 PM   #13
Code05's Avatar
Rewards Points: 1,104
Look closer, I think that is a 3R enclosure with a side hinged door on the left.
Code05 is offline   Reply With Quote
Old 05-27-2012, 09:28 PM   #14
Ahh yes. Thanks. I thought it was part of the wall trim
Old 05-27-2012, 09:43 PM   #15
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Im guessing he means they just bypassed the breaker/disconect and wired the wires from ac whip directly to line voltage coming into the disconect
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 11:16 AM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
An HVAC electrical ? 737Pilot Electrical 5 10-14-2008 12:24 PM
