-   -   Hunter Ceiling Fan: Won't do high speed (http://www.diychatroom.com/f18/hunter-ceiling-fan-wont-do-high-speed-53997/)
ConstantChange 09-28-2009 02:39 PM
I have two of the exact same fan that were installed on the same day (a few years ago). I added the remote module to both of them. The one in the bedroom has a very fast high speed. The one in the living room won't go as fast. It seems like the medium and high speed are about the same. If I remember correctly, the high speed did work at one time.
I've pulled the chain to make sure it's in high speed.
Any advise?
ConstantChange 09-28-2009 03:20 PM
After calling Hunter...it's the switch/light kit. I swapped them and the one in the bedroom makes the one in the living room work.
300zx 09-28-2009 03:37 PM
Sounds like you need to change the dip switches in the fan and remote to different codes for each fan http://www.ehow.com/how_5288790_set-...paign=yssp_art
ConstantChange 09-28-2009 03:48 PM
It's the actual switch with the resistors that is bad. They are sending me a new part. Has nothing to do with the remotes. The remote in the living room will not control the remote in the bedroom.
300zx 09-28-2009 04:00 PM
Ok sorry should have read the post .:thumbsup: Glad you worked it out
