Hunter Ceiling Fan & Light Control #27182 - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 06:12 PM   #16
Hi, sorry in my rather wordy opening remarks I had the colors of the wires but did not reiterate.
The wires in the house switch box are black, red, white and ground.
The wires on the Hunter switch are black, red, blue and green (ground).
When I spoke with the fellow at Home Depot he suggested I try house black to black switchbox, House white to red switchbox, house red to blue switchbox. and that didn't work.
Any ideas?
slrholmes is offline   Reply With Quote
Old 06-01-2010, 06:44 PM   #17
Master Electrician
Rewards Points: 3,678
Any ideas?
See previous post.
brric is offline   Reply With Quote
Old 11-15-2011, 10:33 PM   #18
Do not buy this dimmer. It is junk. I have two of them that didn't even last two years.
The slider arms are underbuilt, and the plastic button ends are hard plastic. Either the slider arm breaks off or the knob end splits into little pieces.
The detent for the off position on the lamp is too stiff, which makes the arms/knobs break faster. The detent gets harder as time goes on. One of mine cannot even be turned off, even after spraying electronic lubricant in it.
drusher is offline   Reply With Quote
Old 03-27-2014, 07:03 AM   #19
is it possible to install this switch with my exisiting wire configuration
I replaced a chandelier with a ceiling fan. the ceiling electrical box only had a 3 wire cable: 1 ground copper, 1 black, 1 white.
I connected the ceiling fan motor and light wires to the black wire in the ceiling box, the neutral to the neutral, the ground to ground.
in the wall I have the same setup: black, white, copper.
this fan/light control switch has red, black, blue, and green. will this work without adding additional wiring? How do I properly connect. Thanks.
helpfix is offline   Reply With Quote
Old 03-27-2014, 03:20 PM   #20
Rewards Points: 332
You need 14-3 run to the fan for that switch. Since you only have 14-2, you can use a standard switch as a "master" switch and use the pull chains to turn the fan and light off separately.
sgip2000 is offline   Reply With Quote
Old 03-27-2014, 03:30 PM   #21
Oso954's Avatar
Rewards Points: 438
The option that would give you separate control from the existing switch box would be a wall mounted remote control.
http://www.homedepot.com/p/Hampton-B...0?N=5yc1vZbvmu
They are readily available from various sources.
Oso954 is online now   Reply With Quote
Old 03-27-2014, 03:35 PM   #22
Master Electrician
You must also install the receiver under the fan canopy.
The Following User Says Thank You to brric For This Useful Post:
Oso954 (03-27-2014)
Old 03-27-2014, 03:49 PM   #23
Master Electrician
Something similar to this. I would use a Hunter equivalent.
Old 03-28-2014, 06:46 AM   #24
thanks for the feedback guys. for now, i just installed a basic switch and we'll have to use the pull strings for fan control. i'll probably end up running another cable at some point since this area isn't difficult to access in the attic.
Timing ceiling light to turn on Delta223 Electrical 6 02-21-2010 09:24 AM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 11:42 PM
GFCI and dimmable halogen ceiling fan light reverend_maynard Electrical 3 11-25-2008 10:05 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 10:16 PM
