Hunter 3 Speed Fan Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2007, 06:09 PM   #1
Went bad and would only run on one speed; bought a replacement and followed directions and wrote down color and exact position of each wire . Black, grey, purple, and green; I've burned out 3 switches so far. The switch is a Fantec and has 8 holes. The outer holes are marked strip 3; L; 1; and 2. Obviously I need help. If y'all can't figure it out, I will buy a new fan, since it will cost less than an electrician.
Thank you
Vince
Annandale, VA
vince is offline   Reply With Quote
Old 06-05-2007, 06:17 PM   #2
L is line and 1, 2, and 3 are the speeds.
If you keep burning out switches, the motor is probably shot so replacing the fan is the best idea.
Master Electrician
jwhite is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
