Humming Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 06:38 PM   #1
Humming Transformer
This device/transformer is inside my furnace room and has an irritating hum. Does anyone know what it it and how to fix it? See attached picture.
richez555 is offline   Reply With Quote
Old 04-20-2010, 07:12 PM   #2
Looks like Doorbell transformers
Do you have an Alarm system ?
Old 04-20-2010, 07:55 PM   #3
Rewards Points: 1,494
There are three transformers shown in the picture. You may find that one is a little loose and tightening it up against the junction box reduces the hum. Or adding a screw to hold the junction box more tightly against the wall may reduce the hum.
There are other tricks, too, like remounting the transformer so a piece of sheet rubber between it and the J-box damps out some of the hum. Do not wrap the transformer; it could overheat as a result.
Pressing your finger here and there may help figure out which transformer is making the most noise.
Old 04-20-2010, 08:28 PM   #4
Probably a loose lamination or a loose portion of a winding. Possibly the factories today soak it in varnish just like always, and that may work for you.
Old 04-21-2010, 07:51 AM   #5
Are these expensive to replace?
Old 04-21-2010, 07:52 AM   #6
Alarm, doorbell and thermostat? Can I replace the noisy one inexpensively?
Old 04-21-2010, 09:23 AM   #7
The three transformers as shown look as if just one could be replaced if needed, easily.
You will have to find out the voltage and current/wattage rating if not marked on the transformer.
Usually it is as simple as disconnecting the wires and unscrewing one ring nut or a few mounting screws.
Some transformers hum because the parts were somewhat immobilized by varnish and now the varnish has shrunk and cracked letting the parts vibrate.
The transformer on the bottom and the one in the middle look as if they have removable side caps. If you are daring you might dissassemble it and wedge a thin piece of fiber in if the paper coil assembly is loose on the central core. This can reduce hum.
The transformer on the left looks as if you would have to undo some small metal tabs and unbend a metal piece that wraps around it in order to look inside.
airhandler (HK61EA005) or transformer problem ? robismyname HVAC 5 04-17-2010 06:36 AM
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 01:07 AM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
