Old 08-23-2012, 01:12 PM   #1
Humming electric panel?
Why do I hear humming from electric panel inside house when hot water heater is running?
MikeVila is offline   Reply With Quote
Old 08-23-2012, 01:35 PM   #2
joed's Avatar
Water heater draw a lot of current. The magnetic field around the wires must be making some loose parts vibrate.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 08-23-2012, 01:41 PM   #3
I've seen/heard this happen when a breaker is very close to tripping. That is close to the maximum amperage for that breaker being used.
Also they will "buzz".
If you have the installation instructions for the water heater, see what size circuit they recommend for that model. Or find the manual on the internet at the manufacturer's web site or call them.
Also a heating element for the water heater may have been replaced with a higher wattage heating element. Check amperage draw for that circuit with an amp meter.
And home water heaters with dual elements are designed for ONLY one heating element to be on at a time. If all cold water, the top element goes on first, then when the water reaches the set temperature, it turns off and then allows power to pass to the lower heating element. That runs until the temperature in the lower part of the tank reaches the set temperature.
Commercial water heaters will run both elements at the same time. So might want to check that only one element is on at a time (or have that checked).
Billy_Bob is offline   Reply With Quote
Old 08-23-2012, 06:49 PM   #4
Pure Genius
Usually means youve got a breaker about to fail. Turn it off. Does it go away? If so you should swap the breaker for a new one.
Dierte is offline   Reply With Quote
Old 08-23-2012, 06:52 PM   #5
Electrical Contractor
kbsparky's Avatar
Does the sound seem to come from the branch circuit breaker?
OR from the main?
You could have one or more breakers on the brink of failure here ...
-KB
Old 08-23-2012, 07:14 PM   #6
Master Electrician
OR from the main?
Agreed. Buzzing can be a strong sign the breaker isn't making correct contact with the bus and is arcing.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-23-2012, 08:30 PM   #7
I did change element out few years back but I would have only got exact replacement. I'm anal like that.
It is coming from the breaker box. When I heard the humming/buzzing I also heard hot water heater running as there across from each other in utility room. I flipped breaker off and that's what it was. Figure just replace breaker? Breakers hardly ever go bad though I always believed?
Old 08-23-2012, 08:40 PM   #8
Pure Genius
Which brand? I see it mostly in murray, siemens and ge breakers
Old 08-23-2012, 10:12 PM   #9
I've had to replace two GE breakers in my panel. The one for my dryer would hum when it was running. The other was a GFI that sounded like a nest of angry bees, and it was unloaded at the time!
It happens. Easy fix.
chemman is offline   Reply With Quote
Old 08-24-2012, 09:07 AM   #10
It is Siemens. I'll have to add to my to-do list! Thx. - Mike
attaching a electric stove/fridge combo unit to service panel bobo Electrical 5 12-03-2010 02:15 PM
Electric panel enclosure question globus999 Electrical 6 11-23-2010 10:30 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
