Humm From Box (transformer?) On Wall Near Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 12:29 PM   #1
Weekend Builder
Crackers's Avatar
Humm from box (transformer?) on wall near thermostat
Hello!
In my closet there is a small box with a small wire coming out of it. The wire seems to go (through the wall) to the thermostat.
The problem is that this small box humms. Sometimes loud, sometimes not. If I grab the box it stops humming; so I think it is vibration based noise.
How can I stop this!!!!!
HELP!
Crackers is offline   Reply With Quote
Old 08-06-2009, 12:45 PM   #2
to the thermostat.
small box humms.
First, tighten all bolts you see.
Since the factory varnish treatment doesn't always work, take off the case, submerge the transformer windings in varnish and let it dry. This stops the loose winding turns from hitting other winding turns at 120 or 60 times per second.
Some forum members report success with this method.
If a new transformer is $10 then you will be paying yourself $1/hr if you DIY.
If you copy the specs from the 'former case we can probably find a source for a cheap new one.
It'll say things like 24 vac, 20VA, 120vac, 50/60 Hz.
HVAC places will overcharge for an electrically equivalent transformer.
Old 08-06-2009, 12:53 PM   #3
Rewards Points: 58
Since the factory varnish treatment doesn't always work, some forum members report success by taking off the case, submerging the transformer windings in varnish and letting it dry. This stops the loose winding turns from hitting other winding turns.
Which forum members. I did not know any had varnish tanks in their basements or garages. Are they doing Vacuum Pressure Impregnation too?
OP.....Just replace it. Or get ear plugs. It's normal.
Old 08-06-2009, 02:36 PM   #4
Originally Posted by J. V. View Post
Which forum members[?].
I thought it was that Leah lawyer lady, but I can't find it right now. Mighta' been a different forum. . .?
If the http://en.wikipedia.org/wiki/Burden_of_proof is on me then I plead http://en.wikipedia.org/wiki/Nolo_contendere
You sure are persistent, Mr. V.
Old 08-06-2009, 03:10 PM   #5
47_47's Avatar
Rewards Points: 44
Teach it the words?
47_47 is offline   Reply With Quote
Old 08-06-2009, 03:17 PM   #6
Originally Posted by 47_47 View Post
Teach it the words?
You are good!
Old 08-06-2009, 03:22 PM   #7
47_47's Avatar
Rewards Points: 44
No, just corny
Old 08-06-2009, 04:14 PM   #8
Rewards Points: 58
You know I mean no disrespect. I thought we would understand each other by now.......John. Varnish Tank
Old 08-06-2009, 05:17 PM   #9
I understand more about Sultini than you. That may be the good news or it may be the bad news.
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 01:24 PM
