HPS Light Fixture Repair/Adjustment - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 07:03 PM   #1
So I bought a few 400W HPS lights pretty cheap.
My goal was to be able to plug them into my home outlets. For one of the lights, I was able to to take off the top to look at the wires. I noticed that it had a 277V wire attached to the 'Hot' wire, so I swapped it with the 120V one. It now works fine.
The problem is with the other lights. When I took off the top to check out what kind of wire is connected to the 'Hot' I found that there was only the 277V wire. No 120V wire in sight. I can see down into the housing through a small hole, and found a few other wires, but none of them were marked 120V. One said CAP, another I think said CX2 and then there was some red wire.
I tried to take off the screws on the side of the ballast to take a closer look inside, but couldn't get them to budge at all.
Also, the sticker/labels on the outside of the ballast are blank under the Volt and Amp categories. Not even a model number in site.
SO my question is: What do I do to get these other lights working in my house? Or is it even possible?
tmac123 is offline   Reply With Quote
Old 09-25-2009, 08:06 PM   #2
Rewards Points: 1,548
You'll have to either:
1. Get a 120 to 277 volt or 240 to 277 volt transformer for the lights,
2. Figure out that (not whether) there is a ballast tap allowing the fixture to accept 120 or 240 volts. You may have to contact the manufacturer and/or get a schematic diagram.
Old 09-25-2009, 08:54 PM   #3
from what I can tell, the company is no longer in business. =(
Where would I find a ballast tap that will do what I need it to?
Old 09-25-2009, 10:48 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it really sounds like you have single voltage ballasts so, you can either buy new ballasts that are 120 volt or you can use a transformer which would make no sense so you either get the ballasts or toss the lights.
Old 09-25-2009, 10:53 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Why does anyone need 400 watt lights in a house?????????
Old 09-25-2009, 11:55 PM   #6
Rewards Points: 1,016
Only need a couple three lights to light the entire house?
Old 09-26-2009, 09:39 AM   #7
2 words: Topsy Turvey. The g/f wants to grow her own tomatoes and basil, parsley...etc. Whats with women? One of them does something, then they all feel they have to as well....
Old 09-26-2009, 04:35 PM   #8
Idiot Emeritus
Rewards Points: 1,492
If a 277 volt HPS fixture is connected to 240 volts, it'll very likely work just fine. Most of these fixtures use a CWA (Constant Wattage Autotransformer) ballast. This type of ballast does pretty well at reduced voltage.
Since it'll be operating at about 15% less voltage, you can expect about a 10% decrease in light, and about a 20% reduction in lamp life.
If the ballast is a HX (High Reactance) type, it'll most likely light up OK, run for a few minutes, the go out. 5-10 minutes later it'll re-light, then go out. This type of ballast needs the correct input voltage.
The only way to know for sure is to look at the connection diagram. Since that is difficult, if not impossible, hook one of them up and see what happens. There's no fire danger, the ballast and lamp both run cooler at reduced voltage.
Rob
micromind is offline   Reply With Quote
Old 09-26-2009, 04:51 PM   #9
A 400w light is probably going to use more power then it will ever pay off in tomatoes & herbs
Is it a Halogen light?
400w might be even too much light depending upon how far away it will be from what you are growing
Tomatoes grow tall, other herbs will be shorter - so need to balance location of the light
Old 09-26-2009, 05:12 PM   #10
Idiot Emeritus
A 400 watt HPS will use about 450-500 watts of power. If it's 277 volt, and operated at 240 volts, it'll use right around 400 watts.
If your power costs $0.15 per KWH (Kilowatt hour), it'll cost about 7 cents per hour.
If it operates only at night (like parking lot lights), each fixture will cost about $21 per month.
Like Scuba said....them's pretty spendy greens!
Rob
Old 09-26-2009, 06:41 PM   #11
One 400 watt fixture might be used to light up an entire yard as opposed to installing multiple smaller wattage fixtures. For best results it should be mounted quite high up, probably at the eaves of a 2 story house if not higher.
400 watts is a common size for street lights. Those in 400 watt mercury and 400 watt sodium are usually mounted about 35 feet above the road although they may also be found on lower bracket arms that were installed with an older light such as an incandescent.
A ballast tap is generally another lug terminal or pigtail on the ballast for connecting up the power. Technically it is a connection to somewhere in the middle of the coil, and you select two of the connections, end(s) or middle(s) which two are meant to go with the supply voltage.
Old 09-26-2009, 07:04 PM   #12
300zx's Avatar
Post
AllanJ He is Growing " Tomatoes" In his House
300zx is offline   Reply With Quote
Old 09-26-2009, 10:43 PM   #13
" Euro " electrician
frenchelectrican's Avatar
Why not take a photo and upload it here so we can able indentify it and one of us will able tell which type of luminaire set up you have.
But with 400 watt HPS that typically draw 460 watts no matter which voltage you are using and this will crank out pretty serious amout of light it will dish out however it is bright orange colour as you see in streetlight luminaire.
There is a specal type of HPS bulb that will used for greenhouse useage and that use standard 400 w ballast set up IIRC it called ARGO not sure if still make them or not.
Now speaking of ballast as other guys they are right on target either add a transfomer to boost it up or swap the ballast to either 120 volts or get one with multi tap { most will useally get in MT (multitap) }
with MT set up you can run either 120 volts or 240 volts however if you have 4 400 w HPS that is the limit on 120 v 20 amp circuit on 240 volts that will be 8 of them.
Yeah there is always a way to get into the ballast housing area and most case you will see a wiring diagram for correct connection set up.
If you have more question just holler one of us will help ya.
Merci,Marc
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
My light fixture / socket question. Getson Electrical 13 02-25-2009 03:41 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
