HPS (High Pressure Sodium) Yard Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 09:22 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
HPS (High Pressure Sodium) yard light
I installed a HPS yard light about 5 years. It was a 70 watt unit. The light was more than I needed so I installed a 35 watt lamp in the fixture. It has worked fine untill about a month ago when it started cycling (? Bad lamp) . I installed the 70 watt lamp that came with the fixture and it worked fine. Bought a new 35 watt lamp. This lamp is cycling. Is this a problem with fixture or is the new lamp defective?
Coastal South Carolina
Old 10-16-2012, 10:26 PM   #2
Master Electrician
Rewards Points: 3,746
I could be wrong but my understanding has been that the lamp wattage must match the internals of the fixture.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
rjniles (10-16-2012)
Old 10-16-2012, 10:38 PM   #3
Rewards Points: 1,440
Correct. Using the wrong lamp can damage either the lamp or the ballast or both.
The purpose of the ballast is to limit the current flowing through the lamp. A high pressure sodium lamp (also a mercury lamp and a metal halide lamp), as it warms up, has its internal resistance go down. Simply applying voltage to the lamp sufficient to strike it will result in an ever increasing current which will result in the lamp's self destruction.
With the wrong lamp in the fixture, the ballast and lamp may reach an equilibrium current that is excessive for the lamp causing it to burn out, or reaches an equilibrium current that is insufficient causing the lamp to extinguish and perhaps restrike again and repeat the cycle which can wear out the ballast.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
Dave632 (10-17-2012), rjniles (10-16-2012)
Old 10-16-2012, 11:19 PM   #4
deverson's Avatar
Rewards Points: 77
You would probably damage the ignitor before burning up the ballast. You have to keep the same wattage lamp that the ballast is designed for. I put labels on fixtures at work but some people cannot or will not read them.
deverson is offline   Reply With Quote
The Following User Says Thank You to deverson For This Useful Post:
rjniles (10-17-2012)
Old 10-17-2012, 10:26 AM   #5
A "Handy Husband"
rjniles's Avatar
Thanks to all who educated me. I have reinstalled the 70 watt lamp and is working fine.
Old 10-17-2012, 12:41 PM   #6
Oso954's Avatar
Rewards Points: 738
The fixtures and lamps come labeled with an ANSI ballast code.
A 70W HPS is a S62 ballast, the 35W is a S76.
All you have to do is match the ballast codes.
Oso954 is online now   Reply With Quote
High inlet pressure aliensweetie Plumbing 8 12-17-2011 09:39 AM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
High pressure bjr23 Plumbing 1 03-27-2007 08:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
How high for front light? Not Sure Electrical 2 08-07-2006 12:37 AM
