HowTo: Adding Two Exterior Lights + Switch, Piggyback New Switch Off Existing Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 01:12 PM   #1
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch?
i'm brand new here as you can see by my post count.
i'm also not much of an expert on electrical wiring.
i was an electrician's assistant for a few summers back in high school where i did trimming for newly framed buildings, but that's pretty much the extent of my knowledge.
that being said, i'd like to add coach lighting to the exterior of my house on either side of my garage door.
i have a light switch inside my garage that controls the single light fixture inside my garage.
i'd like:
a. add a second light switch next to it
b. piggyback the power source of the existing light switch to the new light switch
c. run wiring from that new light switch to control on/off of the coach lighting
i realize i'll have to cut into the sheet rock and add a new junction box to install the second light switch.
my main issue is that i'm uncertain on if piggybacking the power source to the new switch/lights can be done, and how to do it?
what wiring to use, etc.?
ideally if you guys can diagram a basic wiring-101 type diagram for me on this situation it'd be GREATLY appreciated. attached is my basic setup, without wiring because i'm not sure how to diagram wiring.
but the existing light fixture is currently powering the existing light obviously.
thanks
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch?-untitled.jpg
ghost is offline   Reply With Quote
Old 03-30-2009, 06:05 PM   #2
in the existing switch
you should already have a wire nut on the white so all you need to do is add the new wire that's feeding the new switch.
remove the black from the switch, put that in a wire nut with the new wire to the new switch and a short "pigtail" that goes to the existing switch
in the new switch box
wire nut the neutral from the source to the neutral that is going to the lights
black from the source connects to one side of switch
black going to the lights connects to the other half the switch
in the first light box
wire nut the white from the switch with the white to the 2nd light box with a short pigtail to the light fixture
wire nut the black wire the same as you did with the white
in second light box just hook the black and the white to the fixture
Sliver is offline   Reply With Quote
Old 03-30-2009, 06:40 PM   #3
perfect! thanks!
i really appreciate it.
what type of wiring should i get?
looks a lot simpler than i was worried about.
and this would allow both switches to work independent from each other, correct?
meaning the new switch would only control the new lights and the existing switch would continue to only control the existing light?
Old 03-30-2009, 06:58 PM   #4
joed's Avatar
Rewards Points: 12,008
The above drawing assumes you do not have a switch loop. If you open the existing switch and only find a black and white wire then you can not do it.
Old 03-30-2009, 07:00 PM   #5
if this is the case, what would another option be?
there would be no other way to run off of the power source of the existing switch?
i could not install a new switch for the existing that would facilitate this?
Old 03-30-2009, 09:24 PM   #6
Originally Posted by ghost View Post
perfect! thanks!
You will be able to control the new lights with the new switch and the old light with the old switch.
You will probably want to get Romex. You will need to know what size breaker is on that circuit: 15A breaker get 14/2 romex, 20A breaker get 12/2 romex.
If your switch has only two wires in (1black and 1 white taped black) its a switch loop which will require:
Running a three wire cable or from your existing light to the existing switch. at the existing light connect the red to the fixture wire nut the blacks together, wire nut the whites together with a pigtail. In the existing switch box connect the red wire to the switch, wire nut the blacks together with a pigtail to the switch, wire nut the whites together. the rest is the same...
or
Run a new 2 wire cable from the light, make sure you connect to the hot black wire not the switched black wire, to the new switch.
Old 03-30-2009, 09:50 PM   #7
Rewards Points: 150
If you have a switch loop (only the HOT wire is in the switch box, not the neutral/ground) then it will like like this:
In that case you need to tap into the neutral/ground, and run it to the new lights as well.
Then you tap into the source BEFORE the old switch, and send that to the new switch. That way both switches always have power. It will look like this in the end:
it might be easier to pull the neutral/ground back down through the old switch box, meet up with the HOT supply and send all three to the next switch, the HOT goes to the new switch while the neutral/ground just pass right through the box upto the new lights. Pretty simple stuff, I'm sure you got it!
johnnyboy is offline   Reply With Quote
Old 03-31-2009, 08:32 AM   #8
joed's Avatar
You can't do that. You must have the neutral and the hot in the same cable. You also need another wire to the switch box anyway so might as well put in the proper one.
Old 03-31-2009, 12:01 PM   #9
sounds simple enough! thanks guys!
Old 03-31-2009, 01:36 PM   #10
Rewards Points: 506
Send a message via AIM to theatretch85
The diagram JohnnyBoy posted is NOT code compliant and is UN-SAFE! Please do not wire it up this way, follow the advice of joed and the others who have posted here to run the proper wire! If you have to run a new wire down to a new switch box, you can just as easily run a second cable down to the new switch and pull power from somewhere else.
theatretch85 is offline   Reply With Quote
Old 03-31-2009, 05:39 PM   #11
ah ok, i see.
then i'll avoid his diagram.
thanks anyways johnnyboy.
i appreciate it theater tech.
but sliver's explanation is valid? as well as his second in case if it's a switch loop?
Old 03-31-2009, 08:00 PM   #12
ah ok, i see.
The difference is that all conductors of the circuit need to be run together.
Your neutral and ground can't go one way and then have your hot go off to the switch by its self.
If used johnnyboy's diagram just take the hot in to the first new light and make a switch loop to the new switch.
There are different ways to wire this, its up to you to decide whats easiest, and to make sure its too code and safe.
Did you ever look to see if it is a switch loop, or is power feed through the switch box?
Old 03-31-2009, 08:10 PM   #13
no, i have not yet looked as it's behind the drywall.
i want to get a plan together and all materials + time needed before actually cutting into the drywall and starting.
Old 04-19-2009, 03:03 PM   #14
Rewards Points: 26
switch loop
I am trying to add an addional switch to control an additional light and have not been able to get it to work. After reading several other postings i realized i am trying to tap into a switch on a switch loop. Can someone tell me if this is possible and the best way to do it.
Gerrymans is offline   Reply With Quote
Old 04-19-2009, 06:04 PM   #15
joed's Avatar
You should have started your own new thread. The only way to do it is to find an unswitched ower source to use for your new light.
Electrical Question - adding a 3 way switch to existing Light Marcus23 Electrical 5 10-11-2008 09:52 AM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 06:45 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 01:43 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
