How Would You Run The Ground Wire Outside? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 07:32 AM   #1
How would you run the ground wire outside?
I will be running the electricity to my detached garage and was wondering how do you prefer to run the bare #6 ground from the panel to the ground rod. Would you just drill a hole in the siding and run it out or would you use say 1/2" pvc conduit through a lb and conduit to ground level. I know the ground on my shop where the power is going to be coming from is just through a small hole in the wall and I don't really like it like that.
Plumbvoltage is offline   Reply With Quote
Old 06-04-2009, 07:40 AM   #2
BIGRED
Rewards Points: 252
Your #6 ground should be connected to your meter box. Plus I could be wrong but it seems to me that the general consensus among all the pipe benders on this site is that your electrical system should only have one earth ground point, that being the #6 ground wire.
Grampa Bud is offline   Reply With Quote
Old 06-04-2009, 07:48 AM   #3
Rewards Points: 2,350
I suppose you mean that you are running a feeder to your garage from the house? The ground wire can go outside by any means you prefer; it can be a hole down low, or PVC and LB as you mention, or Seal-Tite, etc. If you use a metal conduit, keep in mind there are special bonding requirements.
Old 06-04-2009, 08:22 AM   #4
I believe he's referring to grounding conductor running from the sub-panel to earth.
jerryh3 is offline   Reply With Quote
Old 06-04-2009, 12:43 PM   #5
[quote=InPhase277;282590]I suppose you mean that you are running a feeder to your garage from the house?by quote]
Yes that is what I meant to say.
Old 06-04-2009, 12:43 PM   #6
Yes
switch lacking ground wire anervoustwitch Electrical 17 02-27-2009 04:12 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
