How To Work With Armored Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 09:26 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
How to work with armored cable?
I ran a 240v heater to my panel and it uses armored cable. I had a hell of a time working with that stuff, and kept damaging the wire. There's got to be an easier way! Is there a special tool to use for that? I was just using a dremel and cutting off ends then twisting them off but it was very tedious.
Old 09-21-2009, 09:51 AM   #2
Licensed electrician
Rewards Points: 1,622
I find the Roto-split to do the job without damaging the conductors inside.
Old 09-21-2009, 09:53 AM   #3
47_47's Avatar
Rewards Points: 58
Try one of these
47_47 is offline   Reply With Quote
Old 09-21-2009, 10:24 AM   #4
You could cut the armored cable jacket like this
rgsgww is offline   Reply With Quote
Old 09-21-2009, 01:40 PM   #5
Rewards Points: 160
If I do not have the tool handy (the best option) I just start the cut with tin snips and turn off whats not needed and cut off the excess.
If it worked before you worked on it. You did something wrong.
Old 09-21-2009, 04:26 PM   #6
Electrician
Rewards Points: 794
I like to snap it at the length i need, twist the armour a little, grab the side cutters, cut off the excess and then trim up the armour. Make sure you use anti shorts(the little red things) when you are working with armour cable.
darren is offline   Reply With Quote
Old 09-21-2009, 04:38 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 482
X2
jbfan is online now   Reply With Quote
Old 09-21-2009, 07:08 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
be aware that many folks mistakenly call MC cable AC cable and the inverse. They can look identical from the outside.
AC cable has the bonding wire running through it. 18 AWG I think. MC does not have this bonding wire although there is an MC cable (manufacturers call it MCAP I believe) that has a #10 aluminum bonding wire in if the main conductors are #12.
You do not have to use the anti-short with MC cable although most guys do. Not sure why it would be required on AC and not on MC but that is how it is.
Old 09-21-2009, 08:56 PM   #9
Thumbs up
Method/s of cutting AC (Armored Cable)!
That's the way we worked it before the Roto Split came on the market! (Shhh... But if my boss would see me do it that way, in the good ol' days, I'd sure get an earful, blaming all the shorted connections for the next ten years on my method of cutting BX) But the REAL, legal, original way is to cut with a Hacksaw, diagonally. As one of the posters showed! (No matter what)Don't drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 09-21-2009, 09:02 PM   #10
Thumbs up
Issue of using red- Bushing with BX!
nap (poster #8) In the last paragraph you state "You don't have to use the anti-short (Red Bushing) with it". Try to get past an inspector without using it. As a matter of fact. They come with a "Tip" to show through the box. (No matter what) Don't Drink and Drive, Ever!!!!!!
Old 09-21-2009, 09:38 PM   #11
nap
You talking to me?
nap's Avatar
not required per code or manufacturers directions. Inspector cannot enforce it if you want to argue it.
and realize, I said that is with MC, not AC.
Old 09-22-2009, 11:27 AM   #12
Rewards Points: 160
I never use a hacksaw on any metal cable, only FMC. The metal flex with no wires in it. I prefer the tool. But if I do not have one, then I do what I have to do.
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
1930s armored cable wiring Lisa_90 Electrical 9 08-01-2008 09:24 AM
Armored cable run outside in liquid flexible conduit m_driver Electrical 8 07-06-2008 02:15 PM
