-   -   how to wire up electrical baseboard heaters (http://www.diychatroom.com/f18/how-wire-up-electrical-baseboard-heaters-33077/)
mmd21 12-03-2008 07:47 AM
I have two dimplex electrical base board heaters to connect in series. Here's my problem wiring all previously in place from thermostat to old heaters (now discarded) wires from Panel and thermostat are black and white but from the dimplex heaters two black wires. Duh help?
back ground-- had flooded basement covered heaters replacing them so so I am boxing in to the wires well above the waterline and these wires are blk and white but again heaters have only two black?
Pudge565 12-03-2008 09:14 AM
The incomming black goes to one of the black wires the white also connects to a black. I am not sure if it is recommended to connect them together. I am not sure which side you would do this from since I have never this. You will need a DP breaker both the black and the white go on the breaker.
mmd21 12-03-2008 09:31 AM
Dimplex electric baseboard with two black wires
well as I indicated earlier this is just a heater replacement and the old heaters were black and white wires which ran from heaters to thermostat --thermostat to panel. I'm a bit confused which black goes to which and if they both go to black (three wires in a marrette)where does the white go?
Im installing two heaters in series I assume just to connect the two heaters using my 12/2 wire black to black and white to black just to connect the two heaters in series?
Also to the panel black to power, white to neutral bar and ground to ground correct
Thank you for any help much appreciated
rgsgww 12-03-2008 11:16 AM
These are 220 right?
theatretch85 12-03-2008 12:36 PM
This would be some useful information. It sounds like the old heaters might have been 120 (Op said the old heaters had black and white) and the new ones sound like they are 220 since they have 2 black wires. I would double check the nameplate rating on the heaters and check the wiring for this circuit in the main panel to see how the circuit is configured there. You cannot connect 220 volt heaters to a single 120volt breaker, you'd need a double pole breaker in the panel for those to work (which this would be a good indicator of the circuit its connected to just by looking at the circuit that controls this wire). Also, look at the thermostat, see what its nameplate says as well (whether its rated for 120v or 240 volt).
mmd21 12-03-2008 01:38 PM
electric Heaters
Yeah they were 120 but I upgraded my entrance to a 200amp ten years ago so all is wellin the panel. Sounds like I run all black tied in to gether and don't use the white. then into the panel black to power ground and white neutral
jerryh3 12-03-2008 02:26 PM
A 120V permenant heater with a wall thermostat? Not too common. Can you provide the model number and manufactuer.
GuitarPlayer 12-03-2008 02:40 PM
First...You need to know what voltage your new heaters require, then how many amps will each one pull!
Pudge565 12-03-2008 03:26 PM
Darn I forgot about the voltage. This maybe because I have never seen a 120 heater before. Secondly how many watts are they combined maynot be able to use 12 gauge wire.
jerryh3 12-03-2008 03:57 PM
Attention to detail young Pudge. Collect all the facts, then dispense the correct advice.
Pudge565 12-03-2008 09:52 PM
Point well taken
biggles 12-04-2008 07:33 AM
if you have the black coming off the breaker and the white from the neutral bar then your 120Vs to the heaters.the CB black to the statT1,T2 on stat to the black on the heater(either) the other black to the white from the house.you want the stat to break the in coming HOT (black) from the breaker. and in turn control it into the heater.if you did the white to the stat then down to the heater you would still have the HOT into the heater:no:with the stat off....as long as the new heaters are 115v rated if the old stuff was in series then your breaker should hold the new ones.
jerryh3 12-04-2008 07:41 AM
I looked at the Dimplex website and it appears that all of their permanent baseboard heaters are 240V. I would like to have the nameplate info before giving any more advice.
Pudge565 12-05-2008 08:11 AM
Hmm he has not returned with the information so I guess he either called an electrician or figured it out himself.
