How To Wire Two Switched Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 02:58 PM   #1
How to Wire Two Switched Receptacles
Hello all.
Wondering how I switch 2 duplex receptacles in series. Right now power goes first into single pole switch and then to the receptacles in series. It is all pre-wired with 14 gauge 2 wire. Guy at Home depot said it was possible. Maybe I have wired it wrong but it doesn;t work. Suggestions?
Many Thanks.
Avanzi is offline   Reply With Quote
Old 06-04-2010, 04:00 PM   #2
Master Electrician
Rewards Points: 3,768
Are these the only two receps on the circuit? Do
you want the whole recep switched or 1/2 switched and 1/2 hot continuously?
brric is online now   Reply With Quote
Old 06-04-2010, 04:03 PM   #3
Electrician
Rewards Points: 780
At the first plug there should be a black under each brass screw and a white under each silver screw.
The last plug wired like the first one except there will only be two wires.
At the switch the whites should be together under a wire nut and the two blacks on the switch.
darren is offline   Reply With Quote
Old 06-04-2010, 07:24 PM   #4
Rewards Points: 266
Darren is describing a middle-of-circuit and end-of-circuit receptacle:
http://www.make-my-own-house.com/hom...lectrical.html
Then you need to add your switch between the incoming black wire and the middle-of-circuit receptacle.
Jim F is offline   Reply With Quote
Old 06-05-2010, 05:37 PM   #5
The two receptacles are at the end of the run, power first into switch. I want all plugs switched so I don't need them hot. Me thinks I have to use three wire but I hope not.
Old 06-05-2010, 07:15 PM   #6
Electrician
Rewards Points: 780
Follow what I said before and both those plugs will only be on when the switch is in the on position.
The Following User Says Thank You to darren For This Useful Post:
Avanzi (06-06-2010)
Old 06-05-2010, 07:18 PM   #7
I=E/R
a7ecorsair's Avatar
120V------|sw|-- |Outlet|---|Outlet|
Neutral-----------|*****|---|****|
a7ecorsair is offline   Reply With Quote
Old 06-06-2010, 09:13 PM   #8
Got it! Thanks all!
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 09:55 AM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
