-   -   How to Wire Two Switched Receptacles (http://www.diychatroom.com/f18/how-wire-two-switched-receptacles-72817/)
Avanzi 06-04-2010 02:58 PM
Hello all.
Wondering how I switch 2 duplex receptacles in series. Right now power goes first into single pole switch and then to the receptacles in series. It is all pre-wired with 14 gauge 2 wire. Guy at Home depot said it was possible. Maybe I have wired it wrong but it doesn;t work. Suggestions?
Many Thanks.
brric 06-04-2010 04:00 PM
Are these the only two receps on the circuit? Do
you want the whole recep switched or 1/2 switched and 1/2 hot continuously?
darren 06-04-2010 04:03 PM
At the first plug there should be a black under each brass screw and a white under each silver screw.
The last plug wired like the first one except there will only be two wires.
At the switch the whites should be together under a wire nut and the two blacks on the switch.
Jim F 06-04-2010 07:24 PM
Darren is describing a middle-of-circuit and end-of-circuit receptacle:
http://www.make-my-own-house.com/hom...lectrical.html
Then you need to add your switch between the incoming black wire and the middle-of-circuit receptacle.
Avanzi 06-05-2010 05:37 PM
The two receptacles are at the end of the run, power first into switch. I want all plugs switched so I don't need them hot. Me thinks I have to use three wire but I hope not.
darren 06-05-2010 07:15 PM
Follow what I said before and both those plugs will only be on when the switch is in the on position.
a7ecorsair 06-05-2010 07:18 PM
120V------|sw|-- |Outlet|---|Outlet|
Neutral-----------|*****|---|****|
Avanzi 06-06-2010 09:13 PM
Got it! Thanks all!
