How To Wire A Switch With A Pilot Light - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 01:22 AM   #46
Rewards Points: 512
Just don't want you to get over your head and hurt, is all.
It seemed to me that the responses with diagrams were correct.
OK? Let's be friends, now
Installation is the Reverse of Removal.
Old 06-23-2013, 08:14 AM   #47
jproffer's Avatar
Rewards Points: 706
Originally Posted by sublime2 View Post
You do realize THIS is a doing it yourself website, right?
And you do realize there's a GREAT many times that we advise people that whatever they do, they should NOT do it themselves. Especially in the electrical forum, it's easy to tell when someone's in over their head and it's time to call someone that wont kill themselves fixing the problem.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
sirsparksalot (06-24-2013)
Old 06-23-2013, 08:36 AM   #48
I am hoping to try the suggestions this evening, and if they don't work we are decided we won't have the pilot light anymore so we have a switch that will work right to turn the light inside on and not have it work when it wants too...we are looking for a member of the church who knows electrical to see if they can also help but I was trying to see if you guys could help...I also read up on the voltmeter so I can use it and fine the neutral and hot line safely and right.
jdlight77 is offline   Reply With Quote
The Following User Says Thank You to jdlight77 For This Useful Post:
Old 06-23-2013, 09:21 AM   #49
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
When I was reading your earlier posts, you mentioned red went to common on the old switch. You need to define what you mean by common. It could mean one of two things.
1) The neutral
2) The terminal that is connected with the tab.
Normally how this works is black would go to the untabbed switch terminal. The red would go to the tabbed terminal. The white would go to the (normally) silver neutral terminal at the pilot light.
If that doesn't work, swap the red and the black. If that doesn't work, you will either need to figure out that meter, or get someone in there who knows what they are doing.
Old 06-23-2013, 09:29 AM   #50
1) The neutral
When I say commom mean the tabbed side. I will try it with the black and red switched and also the meter .
Or a professional or someone who knows more than me
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 09:07 PM
New Pilot Light Switch - Neutral From Another Circuit OK? appleye1 Electrical 7 03-07-2011 08:23 AM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
