How To Wire A Switch With A Pilot Light - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 07:01 PM   #31
But I don't have 2 black wires...one black one white one red one green
jdlight77 is offline   Reply With Quote
Old 06-21-2013, 07:10 PM   #32
Oso954's Avatar
Rewards Points: 440
No problem. The red is your load.
Where it says "Remaining black wall box wire (Load) to Brass screw (A1)"
we are substituting the words "red wall box wire (load) to Brass screw (A1)"
Oso954 is online now   Reply With Quote
Old 06-21-2013, 08:10 PM   #33
Okay I was getting really confused
Old 06-22-2013, 12:40 AM   #34
Rewards Points: 506
Originally Posted by jdlight77 View Post
What happens as wired is pilot light stays lite all the time...I do have a volt meter just never used one before so not even sure I would understand it
Why do people who don't know how a basic voltmeter works do their own electrical work?
And, why would they buy a voltmeter without learning to use it?
Installation is the Reverse of Removal.
Old 06-22-2013, 12:49 AM   #35
Resi EC
Rewards Points: 252
What makes you think the red is the load?
Where does it say that the black is always feed? NEC, IRC? just because you wire it that way doesn't mean everyone does.
If the switch was wired the way it was drawn, and the pilot light is always on, and the light works with the switch, IMO the red is fed, black is load.
Get the volt meter, read the instructions, prove me wrong.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-22-2013, 01:52 AM   #36
DIY Enthusiast
sublime2's Avatar
This helps the OP how?
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Kyle_in_rure (06-22-2013)
Old 06-22-2013, 09:31 AM   #37
The reason we do our own electrical is because to replace an exsisting item is usually just an easy switch out, plus to just give you an idea we are a Church and had a refrigeration company in to look at the bad switch and they did nothing which cost us a lot of money, so now we are doing it ourselves.
As for why I have a voltmeter and don't know how to use it is someone gave it to me and it is in my tool box gor someone who would know how to use it to use if needed.
I also agree with the last poster that this comment doesn't help solve my problem.
Old 06-22-2013, 10:15 AM   #38
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Ok, now I'm confused. Why would you bring in a refrigeration contractor to look at a switch? What is the switch for? Are you sure it is line voltage?
The Following User Says Thank You to k_buz For This Useful Post:
jproffer (06-22-2013)
Old 06-22-2013, 10:19 AM   #39
The switch is for our walk-in fridge...on the old switch the red was connected to the common
Old 06-23-2013, 01:25 AM   #40
Rewards Points: 506
Just my opinion. Ain't really that easy, is it?
Can understand why you might think the refrigeration co. might help, but it won't. Electricians put the switches and wiring in, usually.
Old 06-23-2013, 01:28 AM   #41
Rewards Points: 506
It should indicate to him that he needs to bring someone in who knows a bit of what they're doing instead of doing it him/herself and making it worse. And I'll bet that they have their own voltmeter.
Again, my opinion, you're entitled to yours.
Old 06-23-2013, 01:37 AM   #42
DIY Enthusiast
sublime2's Avatar
You do realize THIS is a doing it yourself website, right?
Old 06-23-2013, 02:16 AM   #43
Yes I realize this project hasn't been an easy swap out like we hoped, but that doesn't mean it couldn't have been. Plus that's why I also was on here looking for some expert advice, not someone really to act like I am stupid for admitting that I don't know how something works.
I also again have to agree with the last post again that this is a DIY forum so it would stand to reason, the person asking the question admittedly isn't an expert and asking for advice.
Old 06-23-2013, 02:18 AM   #44
Rewards Points: 506
Really??
Old 06-23-2013, 02:21 AM   #45
Rewards Points: 506
Not expecting you to be an expert. But some basic knowledge would be good.
BTW: have you tired any of the previous responses to your question, or shall we continue this circular tangent?
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
New Pilot Light Switch - Neutral From Another Circuit OK? appleye1 Electrical 7 03-07-2011 09:23 AM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
