How To Wire A Switch With A Pilot Light - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 09:05 AM   #16
Electrical Contractor
kbsparky's Avatar
Do NOT break that tab. The load (light) must be connected to the same side as the pilot light in order for it work properly.
-KB
Old 06-21-2013, 09:14 AM   #17
Okay that's the way we wired it just as the diagram you posted showed..what we do not have is an additional white wire...and this is in side a walk in fridge
jdlight77 is offline   Reply With Quote
Old 06-21-2013, 09:39 AM   #18
Maybe I am just not understanding or getting it...
Old 06-21-2013, 11:27 AM   #19
kbsparky's Avatar
Somehow, this just ain't adding up. The original post stated that you DID have a while wire thus:
Hello we are trying to replace our current switch that has a pilot light with a new one.
We have 1 -Black, 1 - White, 1- Red, and 1 - Green wire to work with....
-KB
Old 06-21-2013, 11:42 AM   #20
Yes we have one white wire...
Old 06-21-2013, 11:52 AM   #21
Here are some pictures of the switch we have and the wires on paper
How to wire a switch with a pilot light-forumrunner_20130621_125152.jpg   How to wire a switch with a pilot light-forumrunner_20130621_125203.jpg   How to wire a switch with a pilot light-forumrunner_20130621_125215.jpg   How to wire a switch with a pilot light-forumrunner_20130621_125225.jpg
Old 06-21-2013, 01:03 PM   #22
joed's Avatar
Rewards Points: 12,364
What happens when it is wired like the above drawing?
Do you have a voltage tester? Can you measure the voltage between white/black and white/red and white/ground?
Old 06-21-2013, 01:36 PM   #23
What happens as wired is pilot light stays lite all the time...I do have a volt meter just never used one before so not even sure I would understand it
Old 06-21-2013, 03:09 PM   #24
Oso954's Avatar
Rewards Points: 994
Are the lights in the walk-in working properly ? On when switch is on, and off when switch is off ? The only problem is the pilot light staying on ?
If you answered yes to all of the above, switch the red and black wires. Black is your line (always hot) and should be on the black screw. Red is your load (switched hot) and should be on the brass screw.
Oso954 is offline   Reply With Quote
Old 06-21-2013, 03:24 PM   #25
Yes light turns on and off inside and yes the pilot light stays on all the time. I want to say we tried the red and black switched but can try again.
Old 06-21-2013, 05:06 PM   #26
kbsparky's Avatar
Black and red are swapped if the pilot stays lit while the light goes out.
-KB
Old 06-21-2013, 05:10 PM   #27
kbsparky's Avatar
Originally Posted by Oso954 View Post
... Black is your line (always hot) and should be on the black screw. Red is your load (switched hot) and should be on the brass screw....
Incorrect.
The screws that are bridged together (black) must be connected to the load (RED) wire.
The lone brass screw must have the feed (black) wire.
-KB
Old 06-21-2013, 05:28 PM   #28
Resi EC
Rewards Points: 252
Originally Posted by kbsparky View Post
Incorrect.
Maybe the red is feed, and the black is the switch leg.
Hard to say without testing.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-21-2013, 05:30 PM   #29
kbsparky's Avatar
You could be correct....
-KB
Old 06-21-2013, 05:46 PM   #30
Oso954's Avatar
Rewards Points: 994
Incorrect.
From the Leviton instructions:
Black wall box wire (LINE HOT) to either Black screw (Common).
• Remaining black wall box wire (Load) to Brass screw (A1)
Edit step 4 of instructions.
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 09:07 PM
New Pilot Light Switch - Neutral From Another Circuit OK? appleye1 Electrical 7 03-07-2011 08:23 AM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
