How to wire a switch from an existing box to a ceiling light?
The first thing to do is to open the switch box, gently pull out the switch, leaving all wires attached and see what is coming into the switch box.
It could be 1, 2, or 3 romex, each with a black wire, white wire, and bare ground unless your house is old, and you don't have a ground. How old is the house?
The best would be to do the above and post some pictures and we'll go from there.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
