How To Wire A Straight Blade Plug? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 02:42 PM   #1
Wek
How to wire a straight blade plug?
How do I wire a straight blade plug? Is it like how I marked it on the picture below? Does it matter which side the detailed wire is? IE. detailed wire on the left, undetailed wire on the right.
Btw, do I need to use tape anywhere for precaution?
Wek is offline   Reply With Quote
Old 03-03-2011, 02:49 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
White/Neutral/ribbed wire on the silver.
Hot/Black on the gold.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Wek (03-03-2011)
Old 03-03-2011, 03:57 PM   #3
Wek
Which one is silver and which one is gold?
The plug did not come any instructions or labels and those metal plates and screws are of the same color. They are not labeled either.
Old 03-03-2011, 03:59 PM   #4
The wider blade on the plug is the neutral.
Wek (03-03-2011)
Old 03-03-2011, 04:08 PM   #5
Wek
I just read something about the wider plug.
The plug that I have is this on:
http://www.leviton.com/OA_HTML/ibeCC...minisite=10021
It's non-polarized so both blades are the same size.
It's there a downside to using a non-polarized plug over a polarized plug?
EDIT: Did some more research, I guess it doesn't really matter which side I put the smooth wire as long as I make sure I plug that hot prong to the smaller outlet socket? Did I get that correct?
Old 03-03-2011, 05:50 PM   #6
Scared Electrician
Saturday Cowboy's Avatar
looking at a receptical the neutral is no the left when the ground is down
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
Wek (03-03-2011)
Old 03-03-2011, 05:59 PM   #7
Wek
Ah, the ground socket is actually on the left and the neutral is the top socket.
Thanks that helps a lot.
EDIT: Finished installing the plug. Had some trouble but managed to do it.
Is there any hazard of electric shocks/fire with this job? It looks like a half-ass job seeing there are copper threads touching the rubber.
How to wire a straight blade plug?-img030.jpg   How to wire a straight blade plug?-img031.jpg   How to wire a straight blade plug?-img033.jpg
Old 03-04-2011, 01:17 AM   #8
Wek
I actually rewired the plug. Took me a couple of tries and about an inch of wire but finally got it neatly tucked in. Some insulation of the wire still touches those metal plates though.
Old 03-04-2011, 06:33 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
In the first picture....the wire on the right....above where it says 'SPT'...it's on backwards...it should loop the other way....the way it is will tend to try and push it off when the screw is tightened....looping it the other way will tend to draw it in when tightened.
Kyle
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
replace plug on aluminum wire appliance mrjules75 Electrical 3 01-09-2011 08:59 PM
questions Nichrome wire goldhunter_2 Electrical 4 01-03-2011 08:01 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
