Old 11-30-2008, 10:38 PM   #1
how to wire romex to 2 3 ways to a half hot receptacle
Can any one please help? I am using romex cable and I have 2 3 way switches and I have to wire it to a receptacle that is half hot half switched. how can I do that? can you please show diagram too? Thank you!
smoothinstall is offline   Reply With Quote
Old 11-30-2008, 11:42 PM   #2
My License Ain't 4 Sale..
You will have to excuse the diagram, I "borrowed" it and modified it to your situation.
how to wire romex to 2 3 ways to a half hot receptacle-three-way-constant.jpg
Old 11-30-2008, 11:55 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
I might be wrong but I believe the op is wanting to get power from a half switched receptacle.
Old 11-30-2008, 11:56 PM   #4
There are several ways so I chose the easiest to explain.
2 wire (power in) into the first switch box.
3 wire from 1st switch box to recep box.
3 wire between boxes.
Ist box:
Tie two whites from power in and 3 wire to recep together.
Tie all 3 blacks together.
Red from 3 wire going to recep goes to common terminal of 3 way switch. Red and white from 3 wire between switches go to the other 2 terminals. Mark the white wire with black tape.
2nd box: Black to common terminal, red and white to the other two in any order. Mark the white wire with black tape.
Recep: Use needle nose pliers to pry the tab between the brass screws off. White to silver screw , red and black to the brass screws. The red will be the switched 1/2.
220/221 is offline   Reply With Quote
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
