How To Wire New Lights And Circuit In A Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2009, 09:27 AM   #1
Average DIYer
Rewards Points: 62
How to wire new lights and circuit in a basement
Hello,
I am starting to add some florescent lights to my unfinished basement.
i am installing about 8 - 10 fixtures (two 32watt T8 bulbs/fixture)in 4 separate areas of the basement and would like the areas on separate switches. My plan is to do the following:
Use 14/2 600v wire
Install a new 15 amp CB and run a line from it to the 4 gang box
Run a line from each switch to each junction box for each light group
Run a line from each light to the appropriate group junction box and tie all the white / black / and grounds together respectively withing the junction box.
Is this correct?
How do I share the power in the 4 gang box?
In the 4 gang box I plan on tie all the whites together and all the grounds together. If my thinking is correct I can pig tail the black feed to each of the switches.
Is my thinking correct?
727driver is offline   Reply With Quote
Old 06-30-2009, 09:36 AM   #2
DIYer
What you propose sounds like it would work, but I think you are making it overly complicated.
Can you draw a picture of what you want to do?
Gigs is offline   Reply With Quote
Old 06-30-2009, 10:01 AM   #3
300zx's Avatar
Yes your thinking is correct. You can pig tail the black feed to each of the switches.And your switch leg(Black going to lights) on the other part of each switch.
300zx is offline   Reply With Quote
Old 07-01-2009, 04:35 PM   #4
Journeyman Wireman
If you run on 14/2 to each switch either the black or the white will be a switch leg or a hot. So one white will make up with a black or blacks.
jbberns is offline   Reply With Quote
Old 07-01-2009, 05:05 PM   #5
300zx's Avatar
I think that would confuse a person with no electrical exp.
Old 07-01-2009, 08:15 PM   #6
Average DIYer
Rewards Points: 62
I am fairly handy around the house but as stated in the previous post I am not an electrican. I understand simple circuits, 3 way switches, and the service panel layouts but that is far as it goes right now.
I would need to see a picuture with a more detailed explanation to undertand eactly what you are getting at.
Old 07-01-2009, 08:32 PM   #7
Journeyman Wireman
Are you running one cable two your switch or two? Not trying to confuse you, but don't want you to end up with a short.
Old 07-01-2009, 08:56 PM   #8
300zx's Avatar
Post
http://www.wiringhelp.com/electrical...-a-switch.html Look at second switch setup
Old 07-01-2009, 09:01 PM   #9
300zx's Avatar
Post
Video How to wire a switch
Old 07-01-2009, 09:20 PM   #10
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
I'm not an electrician, but I have wired my house and shop. Wouldn't they be better off to use 12-2?
Old 07-01-2009, 09:35 PM   #11
Journeyman Wireman
15 amp breaker 14/2 is good enough. Unless he decides to add a bunch more lights!
Old 07-01-2009, 09:39 PM   #12
Average DIYer
Rewards Points: 62
There is 1 common feed for all 4 switches. Then one line going out to the first light in each group.
14/2 is what was used throughout the entire house when it was built. I am also not installing any 20 AMP circuits. I believe 12/2 would be required for 20 amp circuits. Just my novice .02 worth though.
Old 07-01-2009, 09:48 PM   #13
Journeyman Wireman
Do you understand the picture 300zx posted? That is what I'm talking about. From your 4 square box to the switch.
Old 07-01-2009, 10:06 PM   #14
Average DIYer
Rewards Points: 62
No It isn't making sense right now...I will have to think about it some more. According the picture the feed is run to the light first. If this is the case how do I power the lights in the other areas? Am I still using a pig tail in the gang box?
Old 07-01-2009, 10:39 PM   #15
300zx's Avatar
Post
Power(feed) at light run one wire to swich on switch put black on one screw and white on the other(mark white black) and bare on ground then put switch in.At light your feed(power) white goes to nutral on fixture.Black from switch goes on fiture black .White from switch (color it black with marker) goes to black(feed) Just wire it the most common way to be safe (Power at switch then run your switch legs)
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
