How To Wire Multiple Lights In Attic On Same Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 01:07 AM   #1
How to wire multiple lights in attic on same circuit?
Hi all,
I'm a newbie attempting to replace knob and tube wiring in my attic for the overhead lights in my foyer, living room, kitchen, etc. Six lights in total (one is a ceiling fan) will be on one new, 20-amp circuit, using 12/2 wire. Each will have its own switch.
Can someone please describe for me the specifics of how to connect the wires for this setup? (e.g., "Connect the black from the panel and the black from the second switch box with the pigtail...")
I think I want to run power to the light fixture first, rather than the switch, since, in the attic, it seems like the easiest way to route the wires. Does that mean I need to splice three different wires at each light fixture (one from power, one to switch, one to the next light)?
I keep referring back to this thread and the great answer from Chris, which shows how to do this when you run power to the switch first:
http://answers.yahoo.com/question/in...4050322AAaeWgQ
But again, seems like running power from switch to switch will create more of a maze of wires in my attic. Is one method better than another?
Just hoping someone can explain the detailed wiring setup for this scenario. FYI, I already understand the basics and code on how to route wires in the attic (been reading my Home Depot wiring manuals, plus lots of other forum threads). Thanks in advance.
Don
bottlerockett is offline   Reply With Quote
Old 05-12-2011, 08:05 AM   #2
joed's Avatar
Rewards Points: 12,446
You can't do what you want with 12/2 cable. You would need some 12/3 cable. Unless you want to go buy some 12/3 cable you will need to go to the switch first.
Old 05-13-2011, 01:25 AM   #3
Hey, thanks joed. So regarding power-to-switch vs. power-to-light-fixture... is one method more common, or more preferable to the other for any reason, in an attic scenario?
Don
Old 05-13-2011, 01:51 AM   #4
Rewards Points: 512
The attic setting has nothing to do with it. Personally, I go to one of the switches first, because it's easier for me to grasp.
I read the link you provided, and it appears correct.
Old 05-13-2011, 01:52 AM   #5
Rewards Points: 512
BTW: 14/2 (instead of 12/2) is good if you haven't already bought the 12 AWG
Old 05-13-2011, 06:32 AM   #6
Only if he also makes this a 15 amp circuit instead of 20 amp.
thadsaab is offline   Reply With Quote
The Following User Says Thank You to thadsaab For This Useful Post:
sirsparksalot (06-02-2011)
Old 05-13-2011, 07:41 AM   #7
joed's Avatar
Don
The way that uses the least cable is the way I do it. Of course there are new code rules requiring neutral wires in the switch box so switch first often becomes the way.
Old 05-15-2011, 12:34 AM   #8
Hey, thanks all. I'll wire it switch to switch. Went up in the attic and the routing makes sense to me. What's great is that there are already holes in the joists where the current knob and tube runs, so I'll have very little drilling to do.
Old 05-31-2011, 10:34 PM   #9
Hey all,
I'm in the middle of this job, and it seems like I can't possibly cram all the wires I'm using into a normal switch box, and still be up to code. Can you help? How would you do this? To refresh, I'm rewiring the overhead lights in my house on a new circuit, replacing knob-and-tube. In each switch box there are three separate runs of 12-2 Romex (from power, to light fixture, to next switch).
I just did this for one light and I had to pack the wires into a normal metal switch box (3"x3 1/4"). It was hard, especially since I left each wire 8" long. By my calculation, that's 10 wires in the box (6 insulated wires, 1 for ground, 2 for the switch, 1 for metal cable clamps), which seems to be too many for any single-switch box.
What should I be doing here to be in code compliance? Fitting wires in a larger two-gang switch box, but the second half of it is hidden behind the plaster wall? I'm confused. Any guidance appreciated.
Old 05-31-2011, 11:31 PM   #10
Rewards Points: 512
You need a 22.5 cu. in. switch box. They come in single gang. Carlon makes th plastic Blue box: B122A
http://www.carlon.com/Installation_T...Wiring_Box.pdf
Old 06-01-2011, 12:18 AM   #11
Ah, thanks! Didn't know they made a single box that big. Cool.
One more question: Since the plastic boxes don't have wire clamps at the back (just pop-through ports for each run of Romex), does code require me to fasten the wire cables in some other way, to a stud behind the wall or something? so there's no possible tension on the wires in the box.
Old 06-01-2011, 12:26 AM   #12
Rewards Points: 512
yes, it should have the first staple (I believe) within 6" from the box.
Old 06-01-2011, 08:24 AM   #13
Electrician
SD515's Avatar
Rewards Points: 504
Fastening required within 8" if the box doesn't have clamps, 12" if the box has clamps.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
sirsparksalot (06-01-2011)
Old 06-01-2011, 01:20 PM   #14
Rewards Points: 512
Kyle, I tried to find this in the Code, but couldn't. All I could find is the exception listed in 314.17 (C) Nonmetallic Boxes and Conduit Bodies, but that references UF cable. I know it's there, where in the Code can I find this?
Old 06-01-2011, 02:19 PM   #15
Licensed electrician
Rewards Points: 1,502
Try 334.30 also. The 314.17(C) exception lists both UF and non-metallic cables into single gang boxes non-metallic boxes. If a metallic box was used it would be clamped.
SD515 (06-02-2011)
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
replacing wire to ceiling lights jheavner Electrical 5 11-04-2008 07:42 PM
