How Wire Multiple Lights 4 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 11:48 AM   #1
So here is my setup:
- Panel into light # 1 then
- 3-way switch then
- 4-way switch then
- 3-way switch then
Works great but I want to add light # 2 and # 3 after light # 1 before the 3 way switch. Note I have 14/3 wire to each box.
When I tried it everything worked but the lights were dimmed (aka not as bright).
Any help would be appreciated. Attached is my diagram.
NaJoe is offline   Reply With Quote
Old 07-03-2012, 12:48 PM   #2
Rewards Points: 2,512
try this....I only put in one xtra light in diagram
hammerlane is offline   Reply With Quote
Old 07-04-2012, 05:22 AM   #3
Like hammer said.
You show your light hooked in series. If you added a light, they would dim.
Hammer shows the lights in parallel.
jammin06 is offline   Reply With Quote
Old 07-04-2012, 07:24 AM   #4
cleaned it up a little
Old 07-04-2012, 08:41 AM   #5
joed's Avatar
Rewards Points: 11,628
You wired the lights in series. That is why they are dim.
This is what I think you are trying to describe.
How to rewire outlet controlled by light switch? BuckyGunts Electrical 30 04-20-2012 03:18 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Single Switch with Two 3-ways to Control 2 Separate Sets of Lights? LowlyDIYer Electrical 2 10-19-2011 10:11 AM
2 lights from 1 switch, w/ no wire directly from light1 to light2 conradA Electrical 4 03-31-2010 11:25 AM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
