How To Wire The MS4SM-AP-ADC - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 12:31 PM   #1
Question
How to wire the MS4SM-AP-ADC
I am trying to figure out how to connect the MS4SM-AP-ADC properly. All I want to do is hook this relay up to a light so I can have automatic lights for my house. This started as a quick DIY home project that quickly became extremely frustrating. I can get power to the relay, but not out of the relay to the lights without blowing my GFI outlet. Here is a link to the relay with all the technical info.
http://www.automationdirect.com/adc/...9/MS4SM-AP-ADC
I called automation direct about the wiring and the tech support guy treated me like an idiot AFTER I explained to him that this was just a "fun" project I was working on. He said it was no different that wiring a light bulb that may be, but I still need to know which pins to connect to coming out of the relay!
Any help would be much appreciated,
John
jcr1987 is offline   Reply With Quote
Old 04-26-2011, 09:30 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,856
Please explain how you have it wired. I don't understand why it would trip your GFCI unless you have something massively screwed up. I looked at the manual and it really does seem almost as simple as wiring a light switch. The timer has two sets of internal relays, each with three terminals: common, normally open, and normally closed. Connect the two commons (pins 1 and 11) to incoming power and connect your lights to the normally open terminals (pins 3 and 9). Of course, the timer itself needs power on pins 2 and 10 for the internal circuitry.
mpoulton is offline   Reply With Quote
Old 04-26-2011, 09:53 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
WHY are you using such a complicated industrial unit for such a simple task???
A programmable in-wall timer would be MUCH less expensive, MUCH easier and simple to install, a MUCH cleaner install, and the tech guy would not treat you like an idiot for making a simple task into a huge one.
Tags
gfi , ground fault interupter , ms4sm-ap-adc , relay wiring
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 01:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
