How Wire An HP 1.0 Motor Dayton ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 04:46 PM   #1
How wire an HP 1.0 Motor Dayton ?
Hi everyone, o.k I hope you can help me.
I need to replace this motor:
Capacitor Star Motor
HP 1.0
Volts. 115/208-230
Low voltage
O.k I looked inside the motor the wires are in this position :
Yellow - Black are togheter
Red - is empty
Brown - Orange are togheter
Black - White - Yellow are together
The wires are already attached to the motor.
o.k the wires from the main switch are WHITE and BLACK color.
Can you please tell me where should I wire this two.
O.k thanks for your help, I appreciate it.
Have a nice day...!
Conquistador is offline   Reply With Quote
Old 01-27-2012, 05:34 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
How was the old one wired?
rrolleston is online now   Reply With Quote
Old 01-27-2012, 05:46 PM   #3
joed's Avatar
Rewards Points: 12,924
Is there a plate on the motor. usually the wiring for high and low is marked on a plate somewhere. If you post the model number maybe we can find it on the web.
The Following User Says Thank You to joed For This Useful Post:
plummen (01-27-2012)
Old 01-27-2012, 06:32 PM   #4
Ok this is the Model # 6K321BA
Tha label on the motor shows this:
Yellow and Black should go to line 1
Black, White and Yellow to line 2
Line means what ? the wires white and black color from the switch ?
Please take a look:
imageshak.us/photo/my-images/600/wp000159.jpg/
This photo is from the old motor:
imageshak.us/photo/my-images/845/wp000158.jpg/
ok. Thanks again.
Old 01-27-2012, 06:44 PM   #5
biggles's Avatar
line is voltage..if both 2-wires in say line that is the 230 considered hi voltage,then if you see one wire with line and the other with neutral that is low 115V hookup
The Following User Says Thank You to biggles For This Useful Post:
Old 01-27-2012, 07:34 PM   #6
Idiot Emeritus
Rewards Points: 1,492
The Dayton (Grainger) 6K321 is a 1HP thermally protected capacitor-start motor that was built by Emerson and sold under the Dayton brand.
The leads are most likely either black or yellow, and numbered P1, P2, T2, T3, T4, T5 and T8.
The line leads are the incoming power. There are two of them, 3 if you count the ground.
The 115 volt connection to make the shaft turn clockwise when viewed from the back (with the shaft pointing away from you) is;
1) The incoming hot (usually black) connects to P1.
2) P2, T3 and T5 splice together.
3) The incoming neutral (usually white) connects to T2, T4 and T8.
For opposite shaft rotation;
1) Incoming hot connects to P1
2) P2, T3 and T8 splice together.
3) Incoming neutral connects to T2, T4 and T5.
Rob
P.S. I'll be on vacation from about 9 or 10 tonight (1/27) until wednesday (2/1), so someone else will need to answer any questions you have about this motor.
micromind is offline   Reply With Quote
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
