How To Wire In GFCI Outlet From Scratch? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 06:41 PM   #1
Rewards Points: 160
How to wire in GFCI outlet from scratch?
Basement bathroom, I have light switch for light and one for fan. I don't have any electical outlets but want to install a GFCI in the bathroom so my wife can use the hair dryer etc
Is 14/2 wire what I need to run?
Can I wire the GFCI back to the live power before the light switch or the fan switch?
Basically where do I tie it into?
hellothere123 is offline   Reply With Quote
Old 04-25-2010, 06:46 PM   #2
joed's Avatar
Rewards Points: 13,740
If it is a 15 amp circuit then 14/2 is fine. Run the cable back to any unswitched power source. The GFCI connection will go to the LINE side.
Note to many USA readers, the OP is in Canada. We do not require dedicate bathroom circuits or 20 amp bathroom circuits in Canada.
Old 04-25-2010, 06:47 PM   #3
Licensed electrician
Rewards Points: 1,884
The size of the circuit fuse or breaker would determine the proper wire size.
Old 04-25-2010, 07:40 PM   #4
As previously noted, connect the power to the LINE terminals of the GFCI.
I just finished re-locating my basement GFCI to a new position and found that it had been wired to the load terminals originally!
Doing so, completely negated the function of the GFCI.
Old 04-25-2010, 10:28 PM   #5
Rewards Points: 160
sorry but when you say load terminals what do you mean in terms of wiring?
Is it to be wired before the switch?
Old 04-25-2010, 10:43 PM   #6
On the GFCI receptacle two terminals will be identified for the LINE connection.
The other two are only used in case items down stream need to be protected by the same GFCI. These will be identified as the LOAD terminals. These are only used for downstream protection. and in most cases will be unused!
In your case, power would go to the GFCI , then the load would connect to the switch and on to the fan.
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 09:46 PM
Switched GFCI CrazyRay Electrical 9 03-21-2010 05:46 PM
Sump Pump and GFCI Outlet sweetwaters Electrical 10 03-20-2010 06:01 PM
how to wire an outlet? dmoneyz Electrical 10 04-02-2009 01:21 PM
GFCI with no ground wire? gante Electrical 6 03-13-2009 09:17 AM
