How To Wire An Exterior Flood Light To A New Combination Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 02:54 PM   #1
evm
How to wire an exterior flood light to a new combination switch
I have an exterior flood light I would like to connect inside my garage. The garage has multiple "double outlets" inside the garage to plug things into. I want to replace a double outlet with a combination switch/outlet so I can control the flood light on & off. I ran the wire from the flood light to one of the outlets but I am not sure how to connect all the wires.
This is the old outlet connected.
https://www.dropbox.com/s/tqroxcz5ds...2013.37.58.jpg
https://www.dropbox.com/s/hesmbvomne...2013.38.18.jpg
This is the new combination switch.
https://www.dropbox.com/s/2zxhsx105i...131_131646.jpg
This is just another picture of old outlet with new wires from the flood light.
https://www.dropbox.com/s/0brb1jorwl...2013.37.50.jpg
So I want to use the switch for the flood light and still have full use of the one outlet but I don't want the switch turning off the outlet at all; so I have not removed the tab.
evm is offline   Reply With Quote
Old 01-31-2013, 03:00 PM   #2
Rewards Points: 14,000
Power should have been ran to the light, then a switch leg down to the switch.
http://www.bing.com/images/search?q=...electedIndex=4
It also should not be just pluged in to an outlet.
Old 01-31-2013, 03:09 PM   #3
evm
Power was run to the outlet and I am not "plugging" the flood light into the outlet. I have power coming from the sub panel to the outlet. SO you are saying I need to run 50' of wire to connect one flood light to a sub panel?
Old 01-31-2013, 03:17 PM   #4
None of your pictures came through so anyone trying to help is working blind.
As an alternitive it can be done like this.
http://www.bing.com/images/search?q=...electedIndex=1
Old 01-31-2013, 04:05 PM   #5
Rewards Points: 760
On the back of the new combo switch you should see two dark screws labeled as "common". On the other side, you'll have A1 and N.
Don't break the tab. It "feeds" the switch.
Connect the black wire from the feed, not the light, to "common."
Connect the black wire from the light to A1. This will be switched.
Connect all your neutrals together, the two from both lines AND one to the N terminal on the switch.
Ground it.
Done.
AandPDan is offline   Reply With Quote
Old 02-01-2013, 06:31 AM   #6
Ground it.
Done.
I completely agree with AandPDan! Best method. Thanks
adlermark321 is offline   Reply With Quote
Old 02-01-2013, 07:09 AM   #7
evm
Ground it.
Done.
You answered that on perfect, even down to the color of the screws and tiny markings on the plastic, thank you!
The Following User Says Thank You to evm For This Useful Post:
AandPDan (02-01-2013)
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
hard wire from light switch and outlet pennyeagle Electrical 0 08-27-2011 01:00 PM
unable to wire light switch yellow Electrical 4 01-07-2011 08:54 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
