-   -   How to wire an exterior flood light to a new combination switch (http://www.diychatroom.com/f18/how-wire-exterior-flood-light-new-combination-switch-170668/)
evm 01-31-2013 03:54 PM
I have an exterior flood light I would like to connect inside my garage. The garage has multiple "double outlets" inside the garage to plug things into. I want to replace a double outlet with a combination switch/outlet so I can control the flood light on & off. I ran the wire from the flood light to one of the outlets but I am not sure how to connect all the wires.
This is the old outlet connected.
https://www.dropbox.com/s/tqroxcz5ds...2013.37.58.jpg
https://www.dropbox.com/s/hesmbvomne...2013.38.18.jpg
https://www.dropbox.com/s/hesmbvomne...2013.38.18.jpg https://www.dropbox.com/s/wt5zxfs8n6...2013.38.11.jpg
This is the new combination switch.
https://www.dropbox.com/s/2zxhsx105i...131_131646.jpg
https://www.dropbox.com/s/q37fb2kld1...131_131616.jpg
This is just another picture of old outlet with new wires from the flood light.
https://www.dropbox.com/s/0brb1jorwl...2013.37.50.jpg
So I want to use the switch for the flood light and still have full use of the one outlet but I don't want the switch turning off the outlet at all; so I have not removed the tab.
joecaption 01-31-2013 04:00 PM
Power should have been ran to the light, then a switch leg down to the switch.
http://www.bing.com/images/search?q=...electedIndex=4
It also should not be just pluged in to an outlet.
evm 01-31-2013 04:09 PM
Power was run to the outlet and I am not "plugging" the flood light into the outlet. I have power coming from the sub panel to the outlet. SO you are saying I need to run 50' of wire to connect one flood light to a sub panel?
joecaption 01-31-2013 04:17 PM
None of your pictures came through so anyone trying to help is working blind.
As an alternitive it can be done like this.
http://www.bing.com/images/search?q=...electedIndex=1
AandPDan 01-31-2013 05:05 PM
On the back of the new combo switch you should see two dark screws labeled as "common". On the other side, you'll have A1 and N.
Don't break the tab. It "feeds" the switch.
Connect the black wire from the feed, not the light, to "common."
Connect the black wire from the light to A1. This will be switched.
Connect all your neutrals together, the two from both lines AND one to the N terminal on the switch.
Ground it.
Done.
adlermark321 02-01-2013 07:31 AM
Ground it.
Done.
I completely agree with AandPDan! Best method. Thanks
evm 02-01-2013 08:09 AM
Ground it.
Done.
You answered that on perfect, even down to the color of the screws and tiny markings on the plastic, thank you!
