How To Wire In Dimmer In Box With 2 Other Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 09:06 PM   #1
Rewards Points: 12
how to wire in dimmer in box with 2 other switches
I added lights above our tub and i want to put a dimmer on the circuit. There are already 2 switches that feed of same wire. can i wire a dimmer into this box and make it a 3 gang box? this is what the wires look like currently. I have a idea on how to wire it just wanted to check and see if im right. thanks in advance guys! how to wire in dimmer in box with 2 other switches-wire.jpg
wannarace62188 is offline   Reply With Quote
Old 02-20-2013, 11:06 PM   #2
joed's Avatar
Rewards Points: 12,396
I think your drawing is wrong.
The way it is drawn, the light switch will turn on the fan and the outlet. The fan switch will turn on the light only if the light switch is on.
If you reverse the labels on the top cable between the fan and the feed everything will sort of work properly. The receptacle will be always on and the fan switch will control the light and the light switch will control the fan.
Yes you can add a dimmer to control the new lights.
Black wire directly connecting 2 switches? brad34 Electrical 5 07-17-2012 07:41 AM
Help wiring a dimmer BimmerRacer Electrical 8 01-10-2012 12:10 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
Hard Time Trying To Wire 4 Switches kenny357 Electrical 2 10-04-2008 10:44 AM
How do I wire two separate SETS of 3-way switches together? mflagler Electrical 11 08-30-2008 08:47 PM
