How To Wire Different Lights And Switches On One Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 08:19 PM   #1
how to wire different lights and switches on one circuit
I have one circuit that i have different lights running on different circuits. I am attaching a pic of a basic layout. I have no idea what wires need to go to what place at this point. Any help would be amazing.
some lights have 3 way switches and some done but all need to work on one circuit.
Rob
RobertDean is offline   Reply With Quote
Old 05-29-2012, 08:23 PM   #2
Licensed electrician
Rewards Points: 1,018
Do you really mean 3 circuits or just three switched groups of lights?
Old 05-29-2012, 08:28 PM   #3
Each box is a group of lights and switches. Some are one switch and some need a 3way setup. My main problem is how do i link all the boxs so they all run off of one main circuit. Each box needs to turn off and on without affecting the other boxes but share the same main power.
Old 05-29-2012, 08:37 PM   #4
Sparky
Rewards Points: 510
Simplest way to do this is feed all the switches with xx-2(B,W,G.) NM Cable, first, run xx-3(B,R,W,G.) NM Cable between the 3 way switch locations, and run xx-2 cable from all the switches to the lights to be controlled
The other option is to use 'switch loops'(Note diagrams do not meet 2011 NEC requirement for neutrals at switch boxes),
Techy is offline   Reply With Quote
Old 05-29-2012, 09:10 PM   #5
cool! i know i can handle the wireing in each of the 7 boxes but how do i get power to each box? Do i need to pigtail 7 boxes together from a box? is that something that would even meet code?
Old 05-29-2012, 09:17 PM   #6
Sparky
Rewards Points: 510
Running the unswitched hot through the necessary('hot end' of 3 ways, single pole switch) switch boxes first(ie Hot in, hot out, switched hot to lights) would be the simplest solution.
Old 05-29-2012, 09:26 PM   #7
do you have a pic of what you are saying? I think i understand but i want to make sure.
Old 05-29-2012, 10:44 PM   #8
Sparky
Rewards Points: 510
power source coming from the left side
Old 05-29-2012, 10:56 PM   #9
Ok that helps a lot thanks!!!
Old 05-30-2012, 08:11 AM   #10
Rewards Points: 2,504
Decided to put your diagram on here. Quick question. What group of lights/switches will you first be bringing power into??
Is it the lower left corner of the diagram where you have 2 lites and a set of 3-way switches??
hammerlane is offline   Reply With Quote
Old 02-21-2013, 11:00 AM   #11
thanks for the diagram
Hi, I am new to this forum and am building a basement bathroom in my own house.
the diagram posted by techy is very helpful. Thanks very much.
Would it work if all three of the switches were in the same three gang box?
Conceptually it would but what about the build up of heat and amount of wires allowed to fit in the box?
Does each black (hot) run between switches count as an additional wire?
Thanks,
Marcus
marcushurt is offline   Reply With Quote
Old 02-21-2013, 11:18 AM   #12
With a big enough box it is no problem. Below is a diagram I had saved where one swith controlled lites and the other two switches controlled a fan/lite combo.
how to wire different lights and switches on one circuit-fan-light-3-switches.jpg
Old 02-21-2013, 02:52 PM   #13
thanks,
that helps a ton. i appreciated it
Old 02-23-2013, 01:25 PM   #14
Does a ground wire go to the switch also? (in the diagram posted by Techy?)
Was it just left off the diagram to keep it simple?
Old 02-23-2013, 01:26 PM   #15
Sparky
Rewards Points: 510
if the switch has a ground screw, yes
two switches two lights and extra wire jevanich Electrical 1 05-26-2011 06:31 PM
how to wire multiple lights and switches on one circuit Tonglebeak Electrical 9 05-19-2011 10:37 PM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 03:39 PM
How to wire three switches on one circuit Abs777 Electrical 12 03-25-2010 04:15 PM
Multiple lights and switches on one circuit Straightgrain Electrical 5 03-31-2009 08:34 AM
