How To Wire 4 Outlets And A Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 02:30 PM   #1
how to wire 4 outlets and a light
i built my son a new room and need to run the power to it he wants four outlets and a light with a switch to just work the light what is the best and cost efficiently way to do it your self. i was told to run the wire to the outlets and to switch then to light i understand to run black to brass white to silver on the outlets but when i get to the switch i'm a little lost how to hook up switch and from light can any body explain do i hook it all black to brass white to silver
jessewhite is offline   Reply With Quote
Old 03-29-2011, 02:42 PM   #2
joed's Avatar
Rewards Points: 11,998
At the switch connect the two whites to each other and NOT to the switch.
Connect the two blacks to the switch, one to each screw.
Connect the two bare together and to the green screw on the switch.
The Following User Says Thank You to joed For This Useful Post:
jessewhite (03-30-2011)
Old 03-29-2011, 03:27 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Depending on the size of the room, 4 receptacles may not be enough to meet code.
Old 03-30-2011, 12:14 PM   #4
Thumbs up
thanks joed
thats what i thought about the black to switch and white together
Old 03-30-2011, 12:15 PM   #5
its a 12ft by 12 ft
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
