-   -   How to wire a 30A 250v plug and connect it to a well pump control box (http://www.diychatroom.com/f18/how-wire-30a-250v-plug-connect-well-pump-control-box-144363/)
diyorgobroke 05-20-2012 05:27 PM
Hi,
A little about me first...I am a DIY woman because my father did EVERYTHING himself. He read books, asked questions till he got the info he needed. I do not do everything myself, but do what I can. :thumbup:
We have a 3 hp pump for our well and have it wired as well as wired to the control box. Since our home is not in yet but our corn is, we need to get the pump up and running from a generator to water the wee plants.
My husband bought a 4 pin plug for me to wire and connect to the control box, but it did not come with wiring directions! We have #12 well pump wire. I need to know how to connect the wire from the plug to the control box as well as how to connect it to the plug itself. Any help would be most appreciated!
J. V. 05-21-2012 10:33 AM
Do you really think anyone can help you with such little information? Just the mention of "pins" means two things. (1) You are not in the US. (2) You should call someone who knows about these things.
I am not trying to be a smart ass. I am trying to prevent you from hurting yourself or ruining your pump or your control box. Maybe if you posted pictures of the pump, the control box and the plug, someone here might just recognize it and supply the correct information. Good luck and I for one look forward to the pictures.
mpoulton 05-21-2012 03:46 PM
Definitely need more information.
kbsparky 05-21-2012 04:08 PM
I'd be willing to guess that your pump control box requires a straight 240 Volt circuit.
And the so-called "4-pin" plug is a twist-lock type that fits most generators with a 30 Amp 120/240 receptacle. Does it look like this?
http://lh6.googleusercontent.com/pub...VrdlamBYxkQE7w
If so then you will only use 3 of the 4 prongs to operate your pump from a typical 5000 watt generator. You will need a 3-wire cable and use one conductor on each of the hot terminals [x, and y], and the ground terminal [g]. The ground terminal is the "L-shaped" one.
The "neutral" or "white" [w] connection is the one opposite of the grounding terminal and is not used.
Those 2 hot wires connect to the "line" input on your pump controller, and the ground wire connects to the green screw.
