How To Wire 20 Amp Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 10:08 PM   #1
how to wire 20 amp outlet
im trying to wire a 20 amp-250v outlet on my coverered patio for a heater i wired it and my directions say wire the black wire on one side and other black on other side i have 1 white and 1 black wire and ground what should i do
dlt2667 is offline   Reply With Quote
Old 10-04-2012, 10:20 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Both white and black are (or will be) your hots. Both white and black will go on the two-pole breaker you must use.
Re-mark the white wire with a red, blue, black, purple, Sharpie marker at both ends of the circuit.
Old 10-04-2012, 10:21 PM   #3
White acts like a hot in this case. You're using a double 20 breaker correct ?
bmg97 is offline   Reply With Quote
Old 10-04-2012, 10:24 PM   #4
You would first need to make sure that you are using a 2 pole 20A breaker.
I would hire an electrician if you are unsure. Hooking up something incorrectly could fry the components. Since it is a heater, it would probably just be less effective.
AltaSparky is offline   Reply With Quote
Old 10-04-2012, 10:36 PM   #5
single pole i think with nothing on it
Old 10-04-2012, 10:38 PM   #6
You think?
Do you know the difference between a single-pole and double-pole breaker?
Old 10-04-2012, 10:39 PM   #7
single breaker
Old 10-04-2012, 10:41 PM   #8
im using a single breaker
Old 10-04-2012, 10:43 PM   #9
Well, its a heater, theoretically it will work just half as good...
Old 10-04-2012, 10:47 PM   #10
Originally Posted by Speedy Petey View Post
You think?
no i hooked up a 20amp wire to my patio i have a white and black wire my directions on box say line 1 black hot and line 2 black
Old 10-04-2012, 11:01 PM   #11
PLEASE call an electrician. You have absolutely no idea what you are doing.
Old 10-04-2012, 11:01 PM   #12
1/4 as good. Do the math.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Gac66610 (10-05-2012)
Old 10-05-2012, 08:05 AM   #13
Rewards Points: 3,130
Threads like this scare the heck out of me. You'd think anybody attempting a DIY electrial job would at least learn a little about what's involved and how to do it properly. If you screw up plumbing, you'll know it. If you screw up electric, your survivors will know it.
The Following User Says Thank You to md2lgyk For This Useful Post:
Speedy Petey (10-05-2012)
Can I use a piece of wire to connect a grounding plug to an outlet? Smoked Electrical 9 10-14-2011 04:56 PM
3 wire 50 amp outlet with 4 wire cable dlyon2 Electrical 9 10-09-2011 07:32 AM
Converting a 220V two-gang outlet to 110V kevindd992002 Electrical 17 09-30-2011 07:17 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
