How To Wire 20 Amp 250v Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 10:03 PM   #1
How to wire 20 amp 250v plug
Does the black wire (load) go to the horizontal clamp for the plug and the white wire (neutral) go to the vertical clamp on the plug?
saratogan is offline   Reply With Quote
Old 01-24-2011, 10:06 PM   #2
Experienced
Jackofall1's Avatar
See attached
http://www.frentzandsons.com/Hardwar...nfiguratio.htm
Good Luck
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
saratogan (01-24-2011)
Old 01-24-2011, 10:29 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
on a 250 volt recep and plug, it doesn't make any difference. They are both hot wires. As long as you put the ground wire to the smaller pin or it's receptacle terminal, it doesn't matter which of the terminals the other wires go to.
Old 01-24-2011, 11:25 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
As NAP described there isn't a neutral for a 250 volt rated male plug.
What exactly are you doing ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-25-2011, 08:33 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Any chance the poster is in Europe (or other non US locations) and he is dealing with a 220 volt grounded neutral system? 250 volts does not compute.
Coastal South Carolina
Old 01-25-2011, 02:42 PM   #6
nap
You talking to me?
nap's Avatar
250 volts is a standard device rating. It is not the actual supplied voltage. This device is intended to transfer a nominal 240 volts single phase power. If you notice, a plug used for a nominal 120 volt supply will be listed as 125 volts, not 120. check out jackoffall's link. That are simply standard NEMA nomenclature.
Installing a 4 prong dryer plug Amandamayes Appliances 4 07-16-2010 02:17 PM
help! - how do I wire a polarised USA plug?? Unregistered Electrical 7 01-05-2010 08:53 PM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
