How To Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2005, 10:15 AM   #1
rspainhower's Avatar
How to wire
How should I wire this bathroom? Also which breaker should I tie it into? I have one 15 amp breaker that is just running the Bath Fan upstairs and one 15 amp breaker just running the GFCI plug in the Bathroom upstairs.
rspainhower is offline   Reply With Quote
Old 09-23-2005, 12:16 PM   #2
rspainhower,
Is this a new bathroom with no wiring at all?
'Andyman is offline   Reply With Quote
Old 09-26-2005, 09:36 AM   #3
yes it is a new bathroom in my unfinished basement.
Old 09-26-2005, 10:25 AM   #4
rspainhower,
Started a Word.doc on Friday as a reply. My wife has kept me busy on my own current project all week end. Will try to finish it today and upload it to you.
Old 09-26-2005, 08:55 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I'm no pro electrician, just along-time DIYer, but basically this should be pretty simple wiring.
The black (hot) wires go to the brass screws and the white (neutral) go to the silver screws on the switches, and then color connect on the fixtures. The bare (grounds) go the green screws on the switches and green wires of the fixtures. If the boxes are metal, also pigtail the grounds to the green screw on the box. Twist all wires together before wire-nutting for a pigtail, and use the screw connections, not the stab-ins.
If you only have one GFCI outlet, I don't think that this will be sufficient for a bathroom. However, all outlets wired in the same circuit past the GFCI also will be ground-fault protected, if you add some (and wire the GFCI correctly).
You really need at least three or four double receptacles (6-8 outlets) minimum in a bathroom, I think. You will probably need them all to plug in electric shavers, hair dryers, electric toothbrushes, etc., etc. all at the same time.
(Wait for one of the pros here to confirm all of this.)
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-27-2005, 11:10 AM   #6
rspainhower,
Youv'e probably had your first shower in the new bathroom waiting for this
File Type: doc There several ways of running wire to do this.doc (26.5 KB, 149 views)
Old 09-27-2005, 11:12 AM   #7
rspainhower,
Wiring run sketch attached.
Which low voltage wire scozzer Electrical 2 02-18-2007 10:56 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
