How To Use A Digital Pocket Multimeter (to Test AA & AAA Batteries) ? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 10:45 PM   #1
Rewards Points: 79
Question
How to use a Digital Pocket Multimeter (to test AA & AAA batteries) ?
How do i use a Digital Pocket Multimeter (to test AA & AAA batteries) ?
Is there any kind of FAQ on how to test how much juice is left in say a AA battery by using a multimeter?
and while we on the subject. any good FAQs on how to use the device for other uses too?
http://en.wikipedia.org/wiki/Multimeter
ehoez is offline   Reply With Quote
Old 08-31-2008, 11:42 PM   #2
What can I find here?
Winchester's Avatar
Rewards Points: 150
Usually the black wire is common, while the red wire plugs into one of the other two (one for testing voltage and the other current). You'll need to set it for DC for your battery testing and place the setting to the lowest voltage range. Most DC batteries will test around 1.3 - 1.5 VDC new.
Best of luck.
Winchester is offline   Reply With Quote
Old 09-01-2008, 06:14 AM   #3
Whatamess
Multimeter will only test the voltage not the condition. You need a battery tester that works just like one used to test a car battery. It applies a load to the battery.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
The Following User Says Thank You to TazinCR For This Useful Post:
ehoez (07-10-2011)
Old 09-01-2008, 10:12 AM   #4
Rewards Points: 204
Exactly.
Old 09-01-2008, 10:16 AM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
Didn't your meter come with an owners manual??? If not go to the company's web site and down load it for your model. BOB
Old 09-01-2008, 11:02 AM   #6
Winchester's Avatar
Rewards Points: 150
Personally, I don't think there is much of a load on AA or AAA batteries. If you're wanting to test batteries that are in your programable thermostat, smoke detector, or remote controls, I think the voltage test alone will tell you whether or not your batteries are still good. Just MHO.
Two of the three above mentioned items should probably have batteries replaced annually. Keep the old ones and then use it in your remotes.
Tags
battery , multimeter
