I searched and didn't see anything comparable, any help is mightily appreciated!
I have two spare rooms (new home; just moved in 3 weeks ago) that apparently used to have ceiling lights, but no longer do. Both rooms are mirror images of each other: I have 3 walls each with one outlet, and no more ceiling light. There is one switch in each room and both are wired like this pic:
In one room the outlet I want to use looks like this:
And the other room's outlet looks like this:
It looks to me like one of the outlets may have been switched at one time? It's definitely not switched now though.
My question is, assuming the wiring that is currently going into the light switch is no longer needed, what am I supposed to do with it? Do I have to go find it at the junction box in the attic and wire nut it off, or can I wire nut it inside the switch box?
Second question: The outlets are using 14-2 wire, and I assumed that I would have to run 14-3 wire, but all of the stuff I see online is telling me to run 12-2 and 12-3. Which one is correct for this application? I want this to be 100% legal and safe.
The house is located in San Diego County, California. City of Oceanside to be exact.
Forgot to add, these two rooms (which will be used sparingly) along with the porch light, and the entry-way light, are all on one 15 amp circuit.
