How To Transition To Romex From Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 09:02 AM   #1
US ARMY RETIRED
ACR_SCOUT's Avatar
how to transition to romex from conduit
Hello all.
I am in the planning stages for adding lights and receptacle to my finished garage.
I have a surface mounted sub panel. For the lights I can go one of two ways. I can run conduit to the switch location then conduit up into the attic and run romex from light to light. This could be simpler, cheaper and neater. How do I go through the drywall? Do I put a junction box in the attic to terminate at?
The other option is to surface mount conduit to every connection.
Thank you.
ACR_SCOUT is offline   Reply With Quote
Old 12-09-2012, 09:19 AM   #2
TTW
TTW's Avatar
Run / attach the conduit to a junction box, and then put a clamp for the romex, not a problem.
You should to run a green ground wire in the conduit along with the hot and neutral so the romex has a nice solid ground. technically not necessary, as the conduit acts as a ground, but a good idea.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-09-2012, 09:23 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Stub the EMT into the attic and put a romex to EMT connector on that end.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
ddawg16 (12-09-2012), plummen (12-09-2012), Rochsolid (12-09-2012), TTW (12-09-2012)
Old 12-09-2012, 09:45 AM   #4
TTW
TTW's Avatar
I was thinking THHN in the conduit. That cool doohicky would work if running NM in the conduit, but no room for wirenuts!
Old 12-09-2012, 09:46 AM   #5
US ARMY RETIRED
ACR_SCOUT's Avatar
Show that connector begs two questions. Are you allowed to run romex in conduit? If not how do you make the junction without a box?
Old 12-09-2012, 09:47 AM   #6
k_buz's Avatar
Wirenuts...huh?
The Following 2 Users Say Thank You to k_buz For This Useful Post:
electures (12-09-2012), Rochsolid (12-09-2012)
Old 12-09-2012, 09:47 AM   #7
k_buz's Avatar
As long as the pipe isn't outside.
electures (12-09-2012), TTW (12-09-2012)
Old 12-09-2012, 10:37 AM   #8
Rewards Points: 126
This fitting is designed for conduit to Romex transition. I have used this connector to transition to metal flex before, but I do not think the connector is listed for the purpose.
There are no connections here. Just Romex through the conduit and then out the end of this connector.
You could use a regular connector and bushing instead if you prefer.
If you garage is finished, why do you want to surface mount the wiring method for lighting and receptacles?
If you have drywall up, you should have everything recessed and and hidden from site.
Old 12-09-2012, 12:12 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
If you are running individual wires in the conduit, you have to transition to a box for the connections.
It could be right at the ceiling, and just poke the romex into a box with the approved connector.
Old 12-09-2012, 12:26 PM   #10
US ARMY RETIRED
ACR_SCOUT's Avatar
Can the box be in the attic?
Old 12-09-2012, 12:39 PM   #11
TTW
TTW's Avatar
Yes, it just needs to be accessible, as in not buried under drywall or something.
Old 12-09-2012, 12:41 PM   #12
k_buz's Avatar
Didn't like the answers you got in the other thread?
Old 12-09-2012, 12:48 PM   #13
US ARMY RETIRED
ACR_SCOUT's Avatar
The Android app I use acted like it didn't post so I hit submit a second time. Now I see that both of them posted. Sorry.
Old 12-09-2012, 02:08 PM   #14
An old Tradesmen
Rewards Points: 6,870
Merged threads.
The Following User Says Thank You to beenthere For This Useful Post:
ACR_SCOUT (12-09-2012)
Romex in Conduit Outdoors starrapido Electrical 3 11-27-2012 10:00 AM
Does the romex need to be in Electrical Conduit naty0629 Electrical 3 05-01-2012 02:18 PM
Can I mix conduit and romex ACR_SCOUT Electrical 33 02-07-2012 10:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
