-   -   how to transition to romex from conduit (http://www.diychatroom.com/f18/how-transition-romex-conduit-165988/)
ACR_SCOUT 12-09-2012 09:02 AM
Hello all.
I am in the planning stages for adding lights and receptacle to my finished garage.
I have a surface mounted sub panel. For the lights I can go one of two ways. I can run conduit to the switch location then conduit up into the attic and run romex from light to light. This could be simpler, cheaper and neater. How do I go through the drywall? Do I put a junction box in the attic to terminate at?
The other option is to surface mount conduit to every connection.
Thank you.
TTW 12-09-2012 09:19 AM
Run / attach the conduit to a junction box, and then put a clamp for the romex, not a problem.
You should to run a green ground wire in the conduit along with the hot and neutral so the romex has a nice solid ground. technically not necessary, as the conduit acts as a ground, but a good idea.
k_buz 12-09-2012 09:23 AM
Stub the EMT into the attic and put a romex to EMT connector on that end.
http://i2.quinbyhardware.com/6012041.jpg
TTW 12-09-2012 09:45 AM
I was thinking THHN in the conduit. That cool doohicky would work if running NM in the conduit, but no room for wirenuts!
ACR_SCOUT 12-09-2012 09:46 AM
Show that connector begs two questions. Are you allowed to run romex in conduit? If not how do you make the junction without a box?
k_buz 12-09-2012 09:47 AM
Wirenuts...huh?
As long as the pipe isn't outside.
J. V. 12-09-2012 10:37 AM
This fitting is designed for conduit to Romex transition. I have used this connector to transition to metal flex before, but I do not think the connector is listed for the purpose.
There are no connections here. Just Romex through the conduit and then out the end of this connector.
You could use a regular connector and bushing instead if you prefer.
If you garage is finished, why do you want to surface mount the wiring method for lighting and receptacles?
If you have drywall up, you should have everything recessed and and hidden from site.
jbfan 12-09-2012 12:12 PM
If you are running individual wires in the conduit, you have to transition to a box for the connections.
It could be right at the ceiling, and just poke the romex into a box with the approved connector.
ACR_SCOUT 12-09-2012 12:26 PM
Can the box be in the attic?
TTW 12-09-2012 12:39 PM
Yes, it just needs to be accessible, as in not buried under drywall or something.
k_buz 12-09-2012 12:41 PM
Didn't like the answers you got in the other thread?
ACR_SCOUT 12-09-2012 12:48 PM
The Android app I use acted like it didn't post so I hit submit a second time. Now I see that both of them posted. Sorry.
beenthere 12-09-2012 02:08 PM
Merged threads.
