How Are They Used - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2013, 09:23 AM   #1
how are they used
we have a water heater that is running out of hot water to quick i have changed both thermostats and elements but i noticed that their are single throw or double throw thermostats whats th edifference and how do they operate
wayne wright is offline   Reply With Quote
Old 01-09-2013, 09:48 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
If you have an electric water heater, it will most likely be 240Vac. You can switch either one leg or both legs...but the one you want to use is the one that looks just like what is already in there. In most cases you should be able to get the right part based on the model # of the water heater.
But, before you go doing that, what makes you think it's the thermostat? If you water is not hot enough to begin with, that could be the t-stat....but running out? Likely one of three things....your dip tub may have fallen off, one of your electricl elements is bad (water still gets hot but takes longer) or your kids are using too much hot water.
I would look at your elements first. Best way to know is to measure the amps. Your water heater has a posted wattage. Convert that to amps....use a clamp on amp probe to measure the amps going in one leg of your 240Vac. If your within 10-15% of that value, your heaters are ok...
Old 01-09-2013, 10:36 AM   #3
Rewards Points: 1,512
There is a single throw thermostat for the lower element. When the water temperature down there drops far enough the switch goes to the on position.
There is a double throw thermostat for the upper element. As long as the water is hot enough this switch is set to send power to the lower thermostat when needed. When the water up top gets cool the upper element is switched on and also the lower element is overridden. This is because the water heater only has one element on at a time so as not to draw too much current.
If the lower element fails then the upper element will continue to operate but only the water in the upper part of the tank will get heated after which time the upper thermostat switches to the lower element that now does nothing.
If the upper element fails and later its thermostat switches to upper element then the water heater can get stalemated with no heating. It won't switch back to the lower element until the upper half of the tank has been heated which won't happen with the failed upper element. If you don't use enough water at one sitting to activate the upper element then the lower element will keep cycling on and off normally.
If the upper thermostat should get stuck in the lower element switch position then the heater continues to heat the entire tankful but after a big draw it takes longer before the water as drawn from the faucet gets hot. While gas water heaters heat only from the bottom, gas heaters heat a lot faster than comparable grade (standard versus heavy duty) electric heaters even with no defects in either.
(There are a small number of heavy duty water heaters that will have both elements on at the same time but these are not the models sold in ordinary stores like Home Depot.)
Old 01-09-2013, 10:37 AM   #4
JOATMON
ddawg16's Avatar
So that is how they work....I'm on gas.....
Learn something every day...
