How To Test For Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 08:49 AM   #1
Rewards Points: 1,062
how to test for voltage
people,
have a small 18" fluorescent light "fixture"/lamp/whatever, and the bulb does not light when switched on. I removed bulb, and wanted to learn how to test the lamp itself for voltage, as I suspect the cheap junk is at fault.
What contacts do I probe with the 2 leads of my voltmeter? Of course, there are 2 metal contacts on each side.......(it is a SINGLE bulb lamp)
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-24-2011, 09:19 AM   #2
Master Electrician
Rewards Points: 3,678
If you try it and are somewhat lucky, the least of your problems will be to purchase a new meter.
brric is online now   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
jbfan (11-24-2011), noquacks (11-24-2011)
Old 11-24-2011, 09:51 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
The lamp itself will not have voltage, the fixture will.
Thing is, you CANNOT test a fluorescent fixture with a standard multi meter.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 11-24-2011, 10:15 AM   #4
Thnaks, guys. I figured there was something unusual about dang fluorescents. best bet could be buy new bulb, try it, ifn it dont work, return, as one has ruled out the fixture with a assumed OK/new bulb. Then buy new fixtiure. sound good?
Old 11-24-2011, 10:17 AM   #5
Right- what I meant (worded badly) was to test the fixture, not the glass tubular "bulb".......
Old 11-27-2011, 09:11 PM   #6
Rewards Points: 115
if a new tube does not work it is probably the ballast(assuming you have power to the fixture) sockets could also be bad. it will probably be easier in the long run to buy a new fixture. sometimes they cost less than a new lamp and ballast.
pokey is offline   Reply With Quote
How to test new plumbing work for leaks Gusaroo Plumbing 5 07-14-2012 03:06 AM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 11:44 PM
gas-pipe pressure test valve amakarevic Plumbing 7 07-09-2008 02:10 PM
