How To Support Gangable Boxes? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 07:10 PM   #1
how to support gangable boxes?
So the inspector has inspected my rough in for my new home. And the only defect is that the inspector wants the gangable boxes to be support on more then the one side that is attached to the wooden stud. Any ideas?
kwoznia1 is offline   Reply With Quote
Old 09-29-2010, 07:12 PM   #2
the Musigician
DangerMouse's Avatar
Run another 2x4 underneath and attach to that as well?
Or am I misunderstanding?
DM
Old 09-29-2010, 07:20 PM   #3
additional information.....
I am not sure how to do it, the best i think i can do is mount a 12 inch 2x4 stud on the other side so when they drywall, it will support t. this is the boxs that i am using
http://0.tqn.com/d/electrical/1/0/z/...mbined-300.jpg
Old 09-29-2010, 07:23 PM   #4
the Musigician
You mean flat, behind that box? I'm sure he'd accept that as sturdy enough.
DM
Old 09-29-2010, 07:24 PM   #5
the Musigician
Can you take a shot of the area where it'll go?
DM
Old 09-29-2010, 07:27 PM   #6
imagine ptting a 2x4 or 2x6 , what have you on either side of a 2 or 3 gangable box , nailed to both sides to provide stronger structure
Old 09-29-2010, 07:36 PM   #7
the Musigician
Are there holes on the sides of those boxes? Can't see from the pic.
I DO see holes in the rear which can be used to screw them to a flat 2x4 run behind it.
If there are no holes, then no. You cannot add holes either.
DM
Old 09-29-2010, 08:10 PM   #8
Licensed electrician
Rewards Points: 1,028
Are you using these as old work boxes?
If you bought side bracket boxes for new work you could just remove a side without a bracket and add a side with a bracket. You could also go to an electrical supply house and ask for cruise bars.
Old 09-29-2010, 09:07 PM   #9
Why use gangable boxes? Get a double gang nail-on , drywall is not an issue there.
jddavis is offline   Reply With Quote
Old 09-29-2010, 09:09 PM   #10
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
First I hear of this requirement. Suppose you could just have a 2x4 directly behind it extending between both studs. That's probably the easiest and cleanest way.
Old 09-29-2010, 09:44 PM   #11
the Musigician
That's what I said.... Po)
DM
Tags
electrical box , gangable , junction
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 04:07 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Mounting 3 gangable switch boxes mcvane Electrical 11 01-16-2009 09:43 PM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
Gangable old work boxes kornbln Electrical 2 05-27-2008 06:50 AM
